Intercooler Boot
Old Nov 4, 2012 | 11:17 AM
Ivan Solkey's Avatar
Default Intercooler Boot
I just installed the Magnaflow 5" turbo back exhaust kit om my 04 6.0L F250 crew cab, and now it's blowing the boot at the intercooler. I have taken this apart and cleaned with alcohol, the boot, pipe and the clamp, torque clamp to 60 in/lbs and it still blows off.
Suggestions? Who makes a high performance boot kit, that won't blow off?
Old Nov 4, 2012 | 12:00 PM
Lilpooh's Avatar
Take off clamp, clean again, right before install use some hair spray on it, then clamp it down. If that don't work, you may need new boot and clamp.
I've heard RiffRaff diesel makes a good boot.
http://www.riffraffdiesel.com/catego...-RDP-BOOT.html
Old Nov 5, 2012 | 08:17 AM
Mdub707's Avatar
It shouldn't be an issue really. Which side is blowing off? You said at the intercooler, but didn't specify which connection. Crank those clamps down too. Are you sure the plastic part of the intercooler isn't damaged in any way?
Old Nov 5, 2012 | 04:51 PM
It's blowing the lower boot on the pipe side, I'll try the hair spray trick and see if that works, and crank down the clamps, at 60 in/lbs they didn't seem like they where as tight as they could be.
Old Nov 6, 2012 | 09:03 AM
Mdub707's Avatar
Um... the lower boot on the pipe side? Well there are two intercooler pipes going to the bottom of the intercooler, one on the drivers side (cold side) and one on the passenger side (hot side).
Either way, crank those clamps down. That's only 5 ft/lbs.
Old Nov 6, 2012 | 03:02 PM
WOW so between the hair spray, and cranking down the clamp, the issue appears to be gone! Stood on it up a few hills and it help up. Thanks to all I would have never thought to use hair spray, neat trick, Thanks!!
Old Nov 6, 2012 | 04:41 PM
Bigg Redd's Avatar
Stick around kiddo, there's alot to learn on this forum for sure.
Old Nov 7, 2012 | 12:15 AM
dkapp0802's Avatar
i work with clamps all day long. dont worrt about breaking these clamps you only need to worry about in this case is bending the duct. crank em down bud
Cougdiesel
Feb 2, 2016 10:17 AM
Rooster24v
Price Quote - Request A Price
Aug 26, 2015 06:24 PM
DAR_
Jun 6, 2015 03:26 PM
Nealwheels
Jan 10, 2015 01:33 PM
roanokerivermud
Dec 2, 2014 05:42 PM
