kdp tab
Old Nov 2, 2012 | 04:25 PM
1993firstgennewbie's Avatar
Default kdp tab
how thick does the kdp tab need to be I need to cut one real quick
i just found a peice of alluminum 1/8 thick will it work
never mind you guys are too slow I used a peice of 3/32
Last edited by 1993firstgennewbie; Nov 2, 2012 at 04:25 PM. Reason: Automerged Doublepost
Old Nov 2, 2012 | 06:11 PM
Fox's Avatar
Fox
Just about anything thicker than tin foil will work. You have to remember, its not being pressed out by anything physical. It just vibrates and shimmies around. Depending on the motor frequencies... it could vibrate out 1/8"... then vibrate in 1/4". Thats why some go right away... some take years. Just depends on how the thing resonates in its hole.
So yes. It will.
Old Nov 2, 2012 | 06:42 PM
gyayo2012's Avatar
I used a piece of aluminum on my 96 from an old no trespasing sign i had kickin around... idk how its held up havent taken anything apart to see.. but im guessing its good cuz i havent blown a hole in the side of my case and nothing has fallen out of the pan on oil changes!! still have the sighn and im prob goin to use the same on the 95 i just picked up...
Old Nov 3, 2012 | 07:09 AM
JBearSVT's Avatar
This is almost worth putting in a signature, right here. I better shut up now.
Old Nov 3, 2012 | 09:59 PM
tiremann9669's Avatar
I used duck tape
Old Nov 4, 2012 | 04:46 PM
Truck Guy99's Avatar
Seriously? Duct tape?
I have seen people use thin flat steel or things along that line and have it work. Gyayo2012, did you double over thestrip from the sign, or just cut a strip of it out and call it done?
51Hudson
10
Aug 5, 2015 12:32 AM
quiksilver1j
Jul 30, 2015 12:41 PM
xj_crawler
Nov 20, 2014 12:28 PM
