smarty PoD for stock 06 cummins?
Old Nov 1, 2012 | 12:26 PM
cummins.all.the.way.'s Avatar
Default smarty PoD for stock 06 cummins?
I have a 2006 cummins 6 speed with the 610 high output in it. There will be more mods within the next year but i'm looking at getting a smarty PoD so i can show up all these cocky duramax's with there edge juice with attitude around here. as long as a don't run it on the highest setting i should be fine until i get the correct mods for the power, right? let me know your opinion. thanks!
Old Nov 1, 2012 | 01:55 PM
Farmboy 2.0's Avatar
Your stock clutch wont like taking more than 60-90 hp which is catcher setiings 3 or 5. I would recommend getting gauges at the same time so you can watch egts and boost. I would recommend looking into a lift pump as well so you dont run out of fuel supply.
Old Nov 7, 2012 | 09:45 AM
alright, thanks!
Old Nov 7, 2012 | 06:21 PM
dangerous1965's Avatar
Yup your opening a can of crack once you start you can't stop! Start reading but it's ok to put the smarty on your truck #5 at 70 POD will give you great milage!
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
spredfern86
Jan 16, 2015 03:15 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
