A518 Temp Sensor
Old Nov 1, 2012 | 09:03 AM
Grrrr's Avatar
Default A518 Temp Sensor
I changed the trans fluid in my auto last night, and had a bright idea. In putting in gauges the other day i planned to just T into the trans lines with the new sensor. However, I discovered last night that the IISPRO sensor will screw right into the factory sensor location.
Its my understanding that the factory sensor is there only to kick the trans out of overdrive at a certain temp. Is this correct? It serves no other function?
If in fact it doesn't, then I should be able to just disconnect it permanently, and use that location for my ISSPRO gauges sensor correct?
What say you?
Old Nov 1, 2012 | 07:23 PM
montepig72's Avatar
As far as I know, all it does is send an over temp signal back to kick it out of o.d. I was having a problem with the o.d. kicking in and out, so I bypassed the sensor. It never showed any other side effects, and the o.d. problem went away.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
doodieroot
May 10, 2015 11:48 PM
robbyS
Apr 16, 2015 02:22 PM
mule97
Dec 12, 2014 05:05 AM
