loud clicking when engine and heating system are on
Old Oct 31, 2012 | 09:49 PM
darlingperformanceequine's Avatar
Default loud clicking when engine and heating system are on
I have a 2001 dodge 2500 5.9 24v it has a really annoying clicking when any air is on in the cabin not a huge issue was just wondering if that was normal for that year?? Thanks
Old Nov 1, 2012 | 07:58 AM
tworks's Avatar
may be your a/c clutch cycling. try just heat on floor and see if it stops?
Old Nov 1, 2012 | 12:39 PM
No matter what setting it is on it clicks I'm thinking a relay maybe ? Thanks
Old Nov 1, 2012 | 12:41 PM
RAW's Avatar
RAW
How loud, and from what area? A/C will run on every position except vent only.
Old Nov 1, 2012 | 12:48 PM
It's loud enough to clearly hear at idle and low rpms standing outside the truck you can't miss it about every 45 seconds it sounds to becoming from lower left side of engine but it is hard to tell because my truck is very loud
I have a drop off pipe behind the passenger side so very hard to pick up on where noises are cummin from
Last edited by darlingperformanceequine; Nov 1, 2012 at 12:48 PM. Reason: Automerged Doublepost
Old Nov 1, 2012 | 01:12 PM
RAW's Avatar
RAW
Sounds like A/C clutch being every 45 seconds, but its on the right/Passenger side. Try turning the blower motor off, and listening again. If it goes away, it's likely your A/C clutch.
Old Nov 1, 2012 | 07:01 PM
Replaced a/c clutch at work today no clicking thank you very much
