code after egr delete
Old Oct 31, 2012 | 09:18 PM
94cummins12v's Avatar
Default code after egr delete
i drove the truck today to do a coolant flush and the truck threw a few codes some in not worried about but one was a turbo no boost code so i looked around and noticed i must have forgot a hose somewere heres my question on the passenger side of the intake manifold there is a hose fitting that must have gone somewere just curious as to what i would have missed
Old Nov 1, 2012 | 12:09 AM
Lilpooh's Avatar
The hose fitting is for the MAP sensor hose. Behind this bracket is the MAP sensor, there should be a hose going from this sensor to that hose fitting on the intake manifold pass side.
Old Nov 1, 2012 | 07:38 AM
Mdub707's Avatar
Yeah the map hose would certainly do it, it would also make the truck run like crap...
Old Nov 1, 2012 | 11:05 AM
what your pointing to in the picture isnt it this is nlike a little 1/8" barbed fitting straight up out of the passenger runner of the manifold ill get a pic tonight and post it it ran fine just no boost i was worried it was the turbo vanes but at idle the vgt cycle is 65% and at WOT its 40% so those are working id like to know whta hooked to it before i put a pipe plug in it
Old Nov 1, 2012 | 11:41 AM
Lilpooh's Avatar
The red hose in this pic is my MAP sensor hose, it goes from the pass side intake manifold to the MAP sensor behind the bracket in the above pic. With out the MAP sensor hose connected, the PCM isn't getting its input from the MAP to allow proper VGT operation.
Old Nov 1, 2012 | 12:18 PM
Mdub707's Avatar
Right. He's pointing to the other end of the setup there. The hose runs from that barb you see, to where he's pointing. Since you've told us it's not attached to the barb, he's telling you where to look to find the other end of the hose. If you find it where he's pointing in his first picture you're likely to find a hose attached to that at one and and free floating around under the hood at the other end. Take the loose end and put it back on that barb on the intake manifold...
Old Nov 1, 2012 | 09:47 PM
ok ok that secound picture is definatly the one im missing ok thanks for the imput ill take a look when i get home i must have missed it somewere
ok thanks guys i found the hose it was routed behind the turbo i figured it was for something else got everuthing hooked back up and drove it for awhile no codes other than p1000 or obdII test port not complete or something like that
Last edited by 94cummins12v; Nov 1, 2012 at 09:47 PM. Reason: Automerged Doublepost
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
LemayAutoCare
Oct 1, 2014 08:28 AM
