FICM Question.
Old Oct 31, 2012 | 07:04 PM
farm boy's Avatar
Default FICM Question.
Its on a 2004 f 250 and im wondering if anything can affect the voltage. i check it key on 48 volts crank it 47 volt when it first starts it drops to 36 volt and then when i drive it jumps back up to 47 volts. what do you guys think i should do.
Old Oct 31, 2012 | 07:58 PM
Curry's Avatar
What are the volts at idle?
Old Nov 1, 2012 | 07:11 AM
Mdub707's Avatar
Check it again on a cold motor. It shouldn't be dropping at all. How does the truck start/run?
Old Nov 1, 2012 | 06:43 PM
farm boy's Avatar
the truck starts and runs good the rpms jump alittle sometimes but other wise no problem. the motor is cold. i get the readings when i first start it in the morning. and then after i drive it 1 mile or so it jumps up form 36 volts to 47 volts.
Old Nov 1, 2012 | 06:45 PM
Curry's Avatar
So its at 36v after you first start it? Pretty sure its going out.
Old Nov 2, 2012 | 07:21 AM
Mdub707's Avatar
That or maybe you have a charging issue somewhere which isn't allowing it to get up to 48V right away. It should be 48V the entire time. How old are the batteries? I'd have those load tested first, and then have the alternator tested too.
Old Nov 2, 2012 | 03:04 PM
c-tane's Avatar
When my FICM dropped below 48 volts it cost me injector #2... Easy to fix if you pull it up on youtube.
Old Nov 2, 2012 | 10:26 PM
Curry's Avatar
Mine stays between 47-48
PA 24valve
Aug 31, 2015 06:08 AM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
makuloco2000
Feb 15, 2015 02:31 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
