cummins sparks?
Old Oct 30, 2012 | 12:48 PM
jdbigblue12v's Avatar
Default cummins sparks?
i was driving and came to a stop felt my truck struggling to idle so i put it in neutral and it ran better but not normal. i started rolling and then it was sputting and doing everything a bad fuel filter would cause. but what i dont understand is i had a friend rev it when i was at the tail pipe and white smoke + sparks came out. im seriously concerned any help will appreciated..
Old Oct 30, 2012 | 07:29 PM
bladeyamaha's Avatar
Low on fuel, bad lift pump, clogged filter???? I dunno, out of ideas. The sparks is not a good sign at all, IMHO.
Old Oct 30, 2012 | 07:57 PM
RanchhandTCR's Avatar
Somthing bad in your turbo pull the intake boot off and check for play in the compressor wheel.
Old Oct 31, 2012 | 01:52 AM
truck has 3/4 tank turbo has no play but the fuel filter today was colgged and rusty. what could this mean?
Old Oct 31, 2012 | 04:22 AM
jwirth's Avatar
Hows it running with the new filter?
Old Oct 31, 2012 | 05:24 AM
X2?
Old Oct 31, 2012 | 08:48 AM
Rusty fuel filter means a rusty fuel tank, or rusty lines corroded by water that can cause a spark in you ingnition but its also proably running hell on your injectors on injection pump.
Old Nov 1, 2012 | 03:12 PM
the truck runs great now. i have all stainless steel fuel lines, composite tank so its not possible for rust and i think its only rusty since when i did the head gasket i left the intake hor off and the mount for the fuel filter and havent really remebered to do the fuel filter. im doing a full cleanout of the fuel system and will let you guys know how it goes.
Old Nov 1, 2012 | 05:23 PM
sounds good!
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
