Picked up a 2004.5 Cummins, Questions on Trouble Codes...
Old Oct 30, 2012 | 08:42 AM
Mean_sbc's Avatar
Default Picked up a 2004.5 Cummins, Questions on Trouble Codes...
I picked up a 2004.5 3500 quad cab dually on Saturday. The truck has 201,000 miles, a 6 speed tranny, and is in pretty good shape cosmetically. Well, it sounds great idling and the engine has absolutely no blow by from the oil cap or the breather hose. When you give it some throttle it makes a fuel knocking (like low octane pinging in a gas engine) and it smokes black pretty good.. Just driving at 60mph with the cruise set it puffs black smoke pretty good and seems down on power. I'm leaning towards thinking it needs injectors, but I wanted to get your opinions as well. Here are the trouble codes it's showing:
P0148
P0483
P2146
P0251
P0201
P0202
Thanks for all of your help!
Old Oct 30, 2012 | 12:38 PM
BigSilverBullet's Avatar
Yes I would say injectors for sure. I had a LB7 duramax that when mine went out it would make a load clacking noise and wouldn't idle very well. Also when driving it would smoke like a freight train. I wouldn't drive it at all if that is the case cause you could do some major damage from what I understand. When mine went out I let it sit and towed it to the shop when I got the money to fix it.
Old Oct 30, 2012 | 01:05 PM
Mean_sbc's Avatar
I figured with 200k miles on it they oughtta be replaced anyways. I have a set from dieselogic on the way.
Old Oct 30, 2012 | 01:23 PM
what size nozzles are you going with or just stock?
Old Oct 30, 2012 | 01:31 PM
Mean_sbc's Avatar
Just stockers...
klaveric
Oct 20, 2015 07:17 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jesse92cummins
Jun 10, 2015 04:48 AM
mdub4life29
May 9, 2015 10:04 AM
Dakota m
Mar 18, 2015 10:53 AM
