annoying hissing sound
Old Oct 29, 2012 | 10:35 PM
truck junk's Avatar
Default annoying hissing sound
I have an annoying high pitched hissing coming from engine compartment when accelerating and load on engine, ( no there is no cat or varmints, under hood ha ha ) sound more like a high pitched cricket noise. sound like left side of engine so I think that would eliminate turbo squeal but not positive, I have checked for vacuum leaks, everything that works off vacuum works fine, I put new gaskets on air horn and tightened all connections. one thing is the noise came after I installed ispro electric fp gauge I don't know if that's related or not, no leaks, I have run out things to check, has anyone else had this issue or suggest anything to check, so far the only option is to turn the stereo up so I don't have to listen to it,
Old Oct 29, 2012 | 10:44 PM
tiremann9669's Avatar
Intercooler boots ?
Old Oct 29, 2012 | 10:55 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
yeah sounds like boots.
Old Oct 30, 2012 | 03:27 PM
lobsterman04's Avatar
X3 for boost leak.
Old Oct 30, 2012 | 07:45 PM
truck junk's Avatar
I checked the boots, pulled them off and looked, no holes or cracks that I can see and made sure they are clamped on good
Old Oct 31, 2012 | 11:18 AM
Intake horn gaskets?
Old Oct 31, 2012 | 02:38 PM
diesel pap's Avatar
somewhere you have a boost leak.
Old Oct 31, 2012 | 06:05 PM
truck junk's Avatar
intake horn gaskets have been replaced, still leakiing. I put my daughter in the truck with engine running and I got under hood, had her put brake on and in drive and accelerate it, noise sounds like coming from below air horn somewhere but cant pin point it.
Old Oct 31, 2012 | 09:06 PM
Just spray some water and see where it blows it out
GT_Eleanor
Aug 24, 2015 12:11 AM
Timglow546
8
Jun 3, 2015 10:13 PM
JoeRamsey26
May 29, 2015 06:40 PM
mpmcbride42
Apr 7, 2015 08:28 PM
xj_crawler
Dec 4, 2014 09:09 PM
