95 3500 4x4 5 speed 178k miles
Old Oct 28, 2012 | 02:23 PM
ozzking93's Avatar
Default 95 3500 4x4 5 speed 178k miles
Ive decided to sell my truck, its not really practical for me anymore.
it has 178k miles on it and it will need a fuel shut off,the sending unit needs to be replaced(i have one to put in it. the lines rusted on the old one and its sucking air.) and it needs a posi lock 4wd actuator kit. If you want to buy it, ill give you the sending unit to put in it and you can just fix the fuel shut off and 4wd ill let it go for 8000. but if i have to fix it the price will go up.
Performance mods are,no plate,17 degrees of timing,4k governer springs,60lb valve springs,cold air intake,hx40 turbo,4 inch turbo back exhaust,zoom zvt stage one clutch(does not slip),raptor 150 pump,it has a 175 injector pump on it with tst delivery valves(changed injection pumps from the stock auto 160 p-pump) also has autometer boost and pyro gauges.
will come with the toolbox,has aftermarket pioneer speakers,amp wired to the speakers,kenwood head unit,also has a capacitor wired into the truck if you wanted to put a subwoofer in it and it has diamond tucked power seats(will need to be wired in.)
It does have a little rust on the cab corners and a little on the rocker panel, the body is probally about a 6-7 and the paint is fading in places,the dash is cracked but it isnt extremely bad. i will post some pictures here in a few of the current condition of the truck. It does have a 4 inch exhaust stack kit on it but no stack is included and i just havent had time to run it out from the side.
It will start and run, it just wont start really well due to it sucking air but once it starts it runs fine, you have to have the fuel shut off tied up to keep it running and pop the hood to unhook the metal wire to shut the truck off.
I will take $8000 cash or may consider trades.
Here is a link to the album Dually pictures by ozzking93 - Photobucket
http://i135.photobucket.com/albums/q125/ozzking93/Dually/1027121731.jpg
may take less if you want me to put the stock hx35 turbo back on. open to reasonable cash offers aswell. friday i will be ordering a fuel shut off for it and i will try to get the good sending unit in it aswell.
Old Oct 30, 2012 | 07:56 AM
ozzking93's Avatar
Cash talks people throw me some offers, this truck also has a gooseneck ball in the bed.
I will consider serious cash offers.
Old Oct 30, 2012 | 09:40 AM
12vcummins96's Avatar
bump for you bud
Old Oct 30, 2012 | 07:45 PM
ozzking93's Avatar
Thanks man, ill take 7500 cash or as close to it as possible, i need to downsize, maybe once everything is done i can get back into a cummins.
Old Oct 31, 2012 | 09:24 AM
daily bump
Old Oct 31, 2012 | 06:10 PM
ozzking93's Avatar
7000 cash, this truck runs good once its started, im even going to put the fuel shut off on it when i get paid and put the sending unit in it. will also come with a spare set of 215 injectors out of a 97 manual 12v.
6500 without me buying the fuel shut off and you installing the sending unit. This truck would be worth more then this if i fixed it but i need the money.
Old Nov 1, 2012 | 09:32 PM
ozzking93's Avatar
Reduced to 6000 price firm, if it doesent sell for this im trading it in.
Old Nov 3, 2012 | 08:11 PM
ozzking93's Avatar
6000 is the bottom dollar, if it doesent sell by monday at lunch time its getting traded in. so this is the last warning on this truck dont let it slip through your fingers!
Old Nov 5, 2012 | 08:57 AM
turbo2332's Avatar
awsome price man, wish i could come steal it from you
Old Nov 6, 2012 | 08:57 AM
ozzking93's Avatar
well i still have it, i ordered a fuel shut off for it, and im going to install it and the sending unit whenever i get the chance. but the price is going up to $6250 since i had to order the shut off and installing it and the sending unit.
