Truck died after FASS fuel filter/water seperator change help!
Old Oct 27, 2012 | 02:54 PM
Cummins821's Avatar
Default Truck died after FASS fuel filter/water seperator change help!
Hey guys, this is my first filter change with the FASS 95 system. I changed the filters and bump started the truck twice like the website says with filters cracked and it ran for about ten seconds and quit. Now I dont know what to do! Any help would be appreciated.Thanks guys!
Old Oct 27, 2012 | 03:54 PM
RAW's Avatar
RAW
Bump the starter again and again until the air is pushed out. If it won't push out, loosen the inlet bolt to the VP44 and do it again.
Old Oct 27, 2012 | 08:08 PM
joecool911's Avatar
Try bleeding via the tire style valve on the VP44 also. If you got air past that point you may need to crack the injector lines on the head and bleed there.
I read the install PDF for fass 90 and didn't see the step of bleeding the system before/as it enters the vp44. There are videos on the bleed procedure on YouTube. Search for fuel filter replacement.
Last edited by joecool911; Oct 27, 2012 at 08:08 PM. Reason: Automerged Doublepost
Old Oct 29, 2012 | 08:47 AM
h.0.diesel's Avatar
The way the fass fuel system is designed is to purify and take air out of fuel o provide more complete fuel for the system, when u turn ur key to the on position u should here th wining sound from ur fass system this is filling ur filter and also priming ur main supply line to ur vp44 injection pump. Turn ur key on and off to the on and off position 10-20 times after this crack #2,#4,#6 injector lines
And crank until straight fuel comes out, which ur truck will most likely start. fIf u dont here ur fass filter ine at the turning of the key check for loose wire or blown fuse on power feed line next to motor.
Old Oct 31, 2012 | 12:34 PM
FASSAshley's Avatar
To make sure you have purged the whole entire system crack the big filter loose and leave the little filter tight. You should be able to bump your starter a couple times and the pump should kick on and run countously. Here is a video to help out
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
clarthom
8
Mar 5, 2015 07:27 PM
moneypitk5
Feb 12, 2015 11:01 AM
