Tire issue
Old Oct 27, 2012 | 12:28 PM
Diesel firefighter's Avatar
Default Tire issue
Hey guys I bought a set of 324/60/18 BitTorrent terra grappler tires mounted in 18" helo max 8 wheels I attempted to install them today but I'm hitting on the bottom of my truck when I go to turn them I have a 2" leveling kit in the front what else do I need to do to get the tires to fit properly
Old Oct 27, 2012 | 01:53 PM
baddodges's Avatar
Maybe a1in spacer for your rim or a 3in leveling kit?
Old Oct 27, 2012 | 02:46 PM
Curry's Avatar
Higher off set on wheel. Bigger wheel.
Old Oct 27, 2012 | 08:41 PM
tiremann9669's Avatar
Or buy tires that fit the truck you wanna put them on
Old Oct 27, 2012 | 09:47 PM
Curry's Avatar
Easiest thing to do is 1. Take a sawzall and start cutting. 2. Put tires on
Old Oct 27, 2012 | 11:48 PM
Use a torch it's faster
Old Oct 28, 2012 | 10:43 AM
Curry's Avatar
That sawzall will rip through that thin sheet metal haha. Plasma cutter would be faster
Old Oct 28, 2012 | 11:15 AM
I did some trimming on some stuff an got them on I rub a little bit on the inner plastic of the fender well but it's not to bad
Old Oct 28, 2012 | 02:26 PM
Curry's Avatar
I took quite a bit off of the inner plastic and sheet metal.
Old Oct 29, 2012 | 10:55 AM
Karls03's Avatar
How wide are the wheels, what is the backspace? 325 is a bunch of tire for just a leveling kit, especially if there isn't enough back spacing on your wheel and/or you're using more than an 8 inch wheel. BTW, there is no way that I would put a 325 on an 8 inch wheel. But that's another rant
I believe that offset is a poor way to measure wheels. Two different widths with the same ET will NOT have the same backspace. This is the MOST over looked fact in "guessing" what ET to use.
