Gauge Problem
Old Oct 26, 2012 | 11:21 PM
redneckairman's Avatar
Default Gauge Problem
so i have an 01 2500 and when i drive down the road the oil pressure gauge just drops and the check gaugeslight comes on then a few sec. later it gose off and the gauge returns to normal then a few min later it dose it again. dose anyone have any idea what could cause this problem
Old Oct 26, 2012 | 11:46 PM
RAW's Avatar
RAW
Oil pressure sending units can fail and give this problem. It could also be a wiring issue.
Old Oct 27, 2012 | 12:04 AM
so do i need to stop driving it till i fix it or is it still safe to drive for a while till i can get it fixed
Old Oct 27, 2012 | 12:15 AM
RAW's Avatar
RAW
Most likely your engine is just fine, just an electrical issue. Best way to find out is put a mechanical gauge into the oil system. There is a port on top of the oil filter housing that works great for testing.
Old Oct 29, 2012 | 08:02 PM
kerley's Avatar
Mine did the same thing and It worried me aswell. I installed an Autometer op guage only to find the problem was a loose and dirty wire connection to the op sending unit. I know have two working guages. I would clean the wire connector first. Good Luck.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
