215hp 2nd gen injectors on 1gen VE pump
Old Oct 26, 2012 | 05:02 PM
angelic0-'s Avatar
Default 215hp 2nd gen injectors on 1gen VE pump
Will this have a positive effect on my friends 1gen ?
Any ideas for how to build a steady 350hp truck, used for towing and daily driving...
i was thinking 215 sticks from a 2nd gen, HX35/40 hybrid, intercooler, turning the fuel pin 180°, tampering with the power screw and turning the smoke screw a bit in...
How much will that 727 hold up to? He has some sort of a trans, kit... not sure what it is but we're looking to build the tranny
Old Oct 26, 2012 | 05:05 PM
Farmboy 2.0's Avatar
What year first gen?
Old Oct 26, 2012 | 05:26 PM
angelic0-'s Avatar
I think it the engine and tranny comes from a 1990 1gen, it's a non-intercooled with a BANKS exhaust housing upgrade...
Old Oct 26, 2012 | 06:07 PM
1stgenblowingsmoke's Avatar
Won't work. 1st gens have a lower pop pressure then 2nd gens. also the lines wont screw on.
Old Oct 26, 2012 | 06:13 PM
The lines are different sizes and on a 90 the holes for the injectors are too large as well
Old Oct 26, 2012 | 09:38 PM
cumminskid92's Avatar
I could be totally wrong but i believe they make adaptors so the first gen lines will hook up but even then you would need to have the pop pressure set to the correct pressure. Just buy a good set of aftermarket injectors. Somebody will chime in on what injectors to get
Old Oct 26, 2012 | 10:46 PM
angelic0-'s Avatar
Shipping and taxes is killing me, no matter how small of an object i buy....
you can always double the price of the object+shipping...
Old Oct 26, 2012 | 10:54 PM
Contact Jamie at CPP he sells his injectors for 400 bucks atm. If you want a good mild setup i'd say a set of 5x10 or 5x12's will do you very well.
Old Oct 29, 2012 | 11:45 AM
dfiperformance's Avatar
FormerVendor
VE 12 Valve have a 12mm inlet on the injector body P Pump 12 Valve have a 14mm inlet.
Non IC 1st Gens have a 9mm nozzle 91.5-93 and 94-98 12 valves have a 7mm nozzle. You will need adapters to run a 7MM in the 9MM head. They do make them you can find them online I also sell them. They are 50.00 for a set of 6.
A set of 215hp injectors is a small but decent upgrade n the 1st gen trucks however its not going to push you to 350hp. I would look to a set of 5X0.012s or 5X0.014s. And for 350hp on a VE pump hes most likely going to need 5X0.014s.
If you need pricing on injectors PM me.
Chris
Old Oct 29, 2012 | 06:55 PM
BC847's Avatar
I deleted my post as it didn't make much sense when read out loud.
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
cumminsblazer
9
Apr 8, 2015 10:42 PM
moneypitk5
Feb 12, 2015 11:01 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
