Fuel line/filter question need help!
Old Oct 26, 2012 | 07:57 PM
Wallyt's Avatar
Default Fuel line/filter question need help!
Hey everyone new to this site, I am building a 1995 12v from the ground up and need some help with fuel delivery, planning on running a bdf sump to a napa 4770 filter base with a wix 33005Filter (12-15 gph) 2micron nominal, all hydraulic lines with proper fittings to stock lift pump. Question is will the filter let enough fuel to flow? And can the stock lift pump pull it though without strain? Do I still need to use the stock filter? In very cold climate temp goes to -35 during winter months any help will be appreatiated! Thanks in advance.
Anyone?
Old Oct 26, 2012 | 09:10 PM
H.R.D's Avatar
Why don't you upgrade to 1/2 lines and use a remote mount fuel filter and water separator? Put the filters before the Lift Pump to reduce restriction after LP. Or you can get a raptor 100 kit and use the stock filter location. Or use and airdog or fass system that includes LP, lines, and filters in one setup. There are several ways to go about it.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
cummins Pride
Oct 6, 2014 11:28 AM
