Why cummins thermostat?
Old Oct 25, 2012 | 02:10 PM
joecool911's Avatar
Default Why cummins thermostat?
Why are you guys recommending cummins thermostats? I've used more aftermarket therms over the years than I have fingers to count without fail (non cummins). So. Spend $75 or $15. Geno's sells one for $16 as I recall. So they must be advocating using it.
Not opposed to a price diff when it has benefits. Does it in this case?
Old Oct 25, 2012 | 02:45 PM
RAW's Avatar
RAW
Here is something I compiled a while back:
https://www.dieselbombers.com/24-val...fferences.html
Old Oct 25, 2012 | 03:06 PM
joecool911's Avatar
Makes sense. Thanks for the link.
Where is the cheapest place to get a cummins therm? Does anyone have the correct part number?
Old Oct 25, 2012 | 03:25 PM
RAW's Avatar
RAW
I get mine from a Cummins dealership. Price wasn't too bad, but more than a jobber for sure. $65, I Believe, and that is also Canadian. You should be able to get it for less.
I didn't record the number, and I wish I did for this reason.
Old Oct 25, 2012 | 05:19 PM
tiremann9669's Avatar
My NAPA thermostat works fine you just watch the temp go from 140 to 200 then back to 140 constantly. If that dosn't bother you it will save you about 50 bucks
I wonder if you go to the Dodge dealer if you get a Cummins T stat Definitly a big difference lookin at the pics but still mine dosn't bother me.
Last edited by tiremann9669; Oct 25, 2012 at 05:19 PM. Reason: Automerged Doublepost
Old Oct 25, 2012 | 08:44 PM
joecool911's Avatar
Ok. Called my local Dodge dealer. $61, but non in stock. Will have it in a day or two.
Old Oct 28, 2012 | 02:17 PM
willysdeutzdodge's Avatar
I replaced mine with a NAPA one, and instead of being right below the line on temp. guage. its right on it. Never had the problem tiremann descibes, comes up to temp. and stays there.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Sbboozer
Nov 16, 2014 05:52 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
