Problem in the end what? Josep second reflection in my mind
Old Oct 25, 2012 | 04:44 AM
kuku114's Avatar
Default Problem in the end what? Josep second reflection in my mind
All right! Although the long pass is only 60, nfl jerseys china, but Komori or pass! This foot pass is not very good, 60 long pass want to pass quasi need some luck, the higher the value of a long pass ability, then the higher the accuracy the farther the ball, this precision means that you have to range. Take Komori long pass ability value, he can find good teammates the body around 2,3 meters near. A long pass players such as David Beckham, often calculated distance is cm ...
"Well! I think we should continue opening the kicking, so blindly open Bigfoot little too no purpose" field guide Hanks explains.
In fact, a lot of fans think so. But if the Cologne team to continue the kind of style of play, they not only can not kick the wear Kaiserslautern defense would give the team more defensive and more experience. Guardiola's proposal is nothing wrong, In when you lack permeability offensive, let offensive simpler. The two linebackers Kaiserslautern vicious steals, but very edgy, such a simple long-ball maybe will take to the critical role ...
Sure enough, before the end of the first half, Podolski scored the second goal of his this season! This ball is Du Yang launched his long pass found frontcourt Podolski genius wave body carry open the other linebacker Nushe of area! Have to say, this long-range genius waves sometimes really is a flash in the pan!
Goal of the dead ends of the ball tag team of Kaiserslautern goalkeeper Tim Wiese could only watch the ball disappointed!
1 genius waves lit Cologne team morale with a goal! Just a pity that the first half has no time ...... Rhein Energie Stadium, wholesale nfl jerseys, more than 50,000 fans depressed for a long time and finally broke out!
Cologne!! "Cologne!!" Lucas!!! "Podolski!!"
The first half, with a draw Cologne team walked back to the locker room, do not know the second half if they can complete reversal ...
99. Problem in the Which? (Seeking collection!)
PS: more! Seek collection! Seeking recommendations slightly! ! ! o (
_
o For giant giant gave force ah!
First half, Cologne team Kaiserslautern war became a 1 to 1 level. From the statistics, the Cologne team the first half the ball reached 64%, while only 36% of Kaiserslautern. However, the statistics this stuff usually is very deceptive, possession rate in two ways, one is a threat to the possession rate, a blind Daojiao. But today, the Cologne team ball rate are some threats possession rate, the first half and they almost Crimping Kaiserslautern team on the offensive.
Look at a shot the Cologne team the first half, nfl jerseys cheap, a total of 10 shots, including 5-foot shot within the goal range, Kaiserslautern team this data three times, 2 kicking in within the goal range. It can be said, just look at the data, Cologne team should get more goals instead are 1 1 draw.
Cologne team out in the end in what? Could it just bad luck? At least the first half, Du Yang, children's shoes and his teammates think so, Cologne team when kicking the second division last season, have also encountered this situation, the team's opponents in that game Cologne Dewis Fort, the whole game Cologne team is until the last moment to complete the lore.
However, is it really? At the very least, a guy does not think so, this guy is Josep Guardiola. From Guardiola's point of view, the first half of the draw is not just by chance that simple, but Guardiola did not want to clear the Cologne team Where. Anyway, he just felt, not so good kick Bundesliga, Cologne team will not be so easy to win games.
Kaiserslautern, this is not a good nut to crack, they are definitely in the second half will make changes.
When, Ke Yuehan coaches intermission to change the tactical layout, he decided to start in the second half even for two people, the first appearance of the Bell Koeman, the young right-back will be replaced under the exhaustion Guardiola while the first half kick right guard Altintop will Rolfes double waist.
Another alternate appearances is just move this summer from teenager Stefan Kiessling, wholesale jerseys from china, he replaced the first half performance of black Chalmers nothing to tell the truth is too dark since the kick Bundesliga after can say that it is Oops, the first game is too dark also scored a goal, but far less than in the second division of the efficiency in the field. Or confrontation and rhythm problem ah!
Speed up the rhythm, this is Keyue Han has repeatedly stressed in midfield.
"Not quite right to accelerate the rhythm of it? Each other, but all year round in the the Bundesliga kicking team, rhythm they should be faster than we should, if we speed up the rhythm, not to play into the hands of the middle of the other?" Josep melon Diao La in meditation, but he does feel that to speed up the pace of the game is also a Cologne team now only strategy can be implemented.
Problem in the end what? Josep second reflection in my mind.
The second half of the match, authentic nhl jerseys , the Cologne team led by Du Yang began the onslaught of wave after wave. Komori 85 speed and 90 speed startup or disdain for the audience, with his dribbling accuracy has been 80, so Komori many times in the middle of a successful breakthrough. And Du Yang gradually heightening awareness, the combination passes Djorkaeff and he is more and more understanding.
However, often this time Du Yang will be very depressed, he did suddenly passed, but he did not find a passing object, Podolski the first half after scoring the second half, he would be seen dead. Second half Kaiserslautern substitutions and Cologne team, they have a winger with an experienced central defender replaced to strengthen the defense.
burndiesel
10
Feb 7, 2023 01:15 AM
shingi
Off Roading
Sep 30, 2015 11:17 AM
