plzzz help me im stuck and dont know what to do
Old Oct 24, 2012 | 01:17 PM
cummincider's Avatar
Default plzzz help me im stuck and dont know what to do
i was recently experiencing power loss upon heavy excelleration and it would stall so i tried changing my fuel filter then my water seperator filter well i didnt have enough diesel to fill up the water seperator all the way btw this is my first diesel i know im stupid well i sucked up air truck wont start ok and this is were im confused i pressurized my fuel tank bleed over flow valve open low pressure bleed screw been cranking it cranking it one injector is getting fuel outta the line but the others not a drop and ive cranked my battery dead 2 times idk what else to try should i keep cranking i dont want to ruin my pump or starter plz any help will be greatly appreciated thnk u
Last edited by cummincider; Oct 24, 2012 at 01:17 PM. Reason: Automerged Doublepost
Old Oct 24, 2012 | 01:31 PM
Farmboy 2.0's Avatar
You need to crack a few injection lines and have someone close the lines once that fuel is coming out
Old Oct 24, 2012 | 02:37 PM
Yea I got the back 2 and the third is just dripping but battery died again just keep turning it over till it comes out ? On the rest
? And should I crack all of them or just a couple
Last edited by cummincider; Oct 24, 2012 at 02:37 PM. Reason: Automerged Doublepost
Old Oct 24, 2012 | 02:58 PM
I would try that for sure. You made sure everything is kosher on the pump and everything
Old Oct 26, 2012 | 01:18 PM
Update I've tried opening the lines for the last 2 days only getting fuel outta the back injector and nothing outta the others keep trying but nothing any idea air leak or injection pump?
Old Oct 26, 2012 | 09:47 PM
carova_kevin's Avatar
May have a pinhole or Dryrotted fuel supply line. There is a rubber section tucked behind IP that's where mine was leaking. Good luck
Old Oct 27, 2012 | 12:57 PM
dfiperformance's Avatar
FormerVendor
try just cracking #1 at the pump. Thats what I always do.
Old Oct 27, 2012 | 01:43 PM
It's all good I got it last night finally thanks u guys
Old Oct 28, 2012 | 10:04 PM
FormerVendor
Good deal
Old Oct 29, 2012 | 03:26 PM
Have you tried pressurizing the system with the plunger in the lift pump as well.
