Manual Tow Mirrors
Old Oct 24, 2012 | 11:17 AM
FarmersDaughter92's Avatar
Question Manual Tow Mirrors
I recently bought manual tow mirrors for my 2002 Cummins 2500. I took the drivers door panel off and got the old mirror off. When I went to install the tow mirror the studs are alot longer than the stock mirrors. Also they are not fitting flush with the truck. Is this normal? I called several places an they said that these mirrors are the ones for this truck help?
Also these are not heated or electric.
Old Oct 24, 2012 | 11:37 AM
RAW's Avatar
RAW
They should fit fine. Seems a few people, including myself, have had issues mounting these mirrors. My studs were too short, and I had to thread them out a bit to work. Maybe yours aren't threaded into the housing far enough.
Old Oct 24, 2012 | 01:15 PM
Ltk's Avatar
Ltk
I had trouble also. Fiddle around with them for a while. Took me probably 3 hours JUST to get the mirror on correctly... good luck!
Old Oct 25, 2012 | 08:34 PM
dango's Avatar
My mirrors came with a backing plate to make up for the longer studs. they also didn't fit flush until i got the bolts tightened down good
Old Oct 25, 2012 | 09:37 PM
Ltk's Avatar
Ltk
yea they are a pain. helps to have 2 people by the way!
Old Oct 25, 2012 | 09:59 PM
chadcycle 2500's Avatar
Yes I was wondering if you had backing plates or not,The stud length can be a issue also
Old Oct 26, 2012 | 12:17 AM
blacksally's Avatar
they also self the backing plate bracket youll want to get so they dont shake!!!! if not you will have them rattling ive seen
Old Oct 26, 2012 | 10:29 AM
Ltk's Avatar
Ltk
Yea without the support brackets they are pretty shakey!
KTWillys
6.7 Liter Dodge Cummins 2013+
9
Mar 5, 2016 06:41 PM
May 7, 2015 11:50 AM
Boostaddiction
May 4, 2015 06:33 AM
