Fellas......
Old Oct 23, 2012 | 11:00 PM
TTipsword's Avatar
Default Fellas......
Got a 12v hx35 today....Whats the best way to set up the wastegate for my 92? i would like to stay at 30 PSI and i can already do it with the stocker.....any other things i might run into when i install it that i need to be aware of would be greatley appreciated.
Old Oct 23, 2012 | 11:28 PM
1stgenblowingsmoke's Avatar
Get a 2nd gen adjustable boost elbow n plumb it into an empty port in the intake then run a line over to the wg n set it to 30 psi.
Old Oct 24, 2012 | 11:25 AM
TTipsword's Avatar
Thanks man
Old Oct 25, 2012 | 11:29 PM
TTipsword's Avatar
so with the wastegate working i shouldnt need to worry about drive pressures beiin to hi right. also how will the hx35 stach up with egts compared to the h1c.
Old Oct 26, 2012 | 12:06 AM
As long as your not going over like 35 psi your fine. Can't tell you that one I just know with an hx35 with a non gated 16cm exh housing, 180 horse p pump and 120 horse fuel plate with afc tuning I cant get over 1150 passing. climbing steep mountains i can keep it at 1150 and tow at 100-110 kmh so it's not bad. but I have a bigger exh housing then an hx35 comes with so that helps.
Old Oct 30, 2012 | 10:45 PM
TTipsword's Avatar
well got a non-adjustable elbow...wel will see what that does. might have to enlarge the orfice.
Old Oct 31, 2012 | 12:08 AM
Enlarge it? No it will open the gate now at about 17 psi. What you can do to get 30 psi is put a hose clamp on the rubber line or put in a needle valve so you can accuratly adjust the pressure that the gate opens at.
Old Nov 7, 2012 | 01:42 PM
TTipsword's Avatar
1stgen, since your the only one with any help for me another question. The fittings for the oil line are different. any idea what size fitting i need to get the line to reduce to the hx35? or should i just look for an oil line off of another dodge?
Old Nov 7, 2012 | 02:08 PM
On your h1c there should be a fitting between the turbo and the line. take it out n put it in the hx35 if u dont have one in it. the hx35 uses the same feed line as the h1c. if not try a line n adapter off a p pump truck with an hx turbo. i got one of the fittings at my house but thats 4 hours away n I dont plan to be back soon.
Old Nov 8, 2012 | 09:19 PM
u2slow's Avatar
^^Thats what I did.
I have a boost elbow on mine too, but don't have a gauge yet. It definitely spools faster than the H1C.
