what else is needed?
Old Oct 23, 2012 | 04:22 PM
CUMMINStagetcha19's Avatar
Default what else is needed?
I got ahold of a 47rh trans (2wd) harness for the trans and the controller, the flex plate and the engine plate. what else do i need for my swap? any linkages cables etc?
Old Oct 25, 2012 | 12:18 AM
jwirth's Avatar
You will have to mount the linkage in a different spot on the frame had to move mine one hole back. only had to drill one hole. I was able to use my rear driveshaft but had to have the front rebuilt (wornout) and they made it longer. If going in a 4x4 the 4x4 shifter may need spacers to offset the shift mount as on some the cases are different. 1/2" to 3/4" spacer for the 3 mounting bolts. I didn't change the controller. Only have a manual on/off lockup
Old Oct 25, 2012 | 09:51 AM
Ok thank you. I already have OD in my truck, so i just need the ability to lockup. Anything for the 46 will work with some modifications for the 47? Other thing the "throttle" cable for the trans, what did you do with it? is it a push not pull type? May PM you a little later on when i get to the build on some "what did you do" thanks
Old Oct 26, 2012 | 12:23 AM
jwirth's Avatar
You can PM me if you like.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Crwln73
Jun 24, 2015 05:14 PM
klein444
Jun 20, 2015 11:48 PM
SixSpeed
Jan 11, 2015 01:41 AM
