Cooling system flush 24 valve procedure
Old Oct 23, 2012 | 10:01 AM
joecool911's Avatar
Default Cooling system flush 24 valve procedure
I've searched the archives and have not found a decent description of how to do a thorough flush. I need to do it right away as I changed a water pump and have not added any anti freeze yet.
Radiator shop wants about $200. Includes a new thermostat, but I doubt it's a cummins.
Old Oct 23, 2012 | 10:17 AM
RAW's Avatar
RAW
I have always used "10 minute rad flush", and ran it for 2 hours at 1200 RPM. This is a procedure that a well know Rad shop gave me years ago. After that, its a drain, refill with water, run, repeat until the water comes out clean, and not milky.
Old Oct 23, 2012 | 12:05 PM
brianb883's Avatar
I didn't use a "flush" product, I just drained the radiator via the plug on the drivers side bottom. There was alot of gunk that quickly blocked the plug from the inside, so I used a garden hose to flush out the radiator from the top with the drain open.
I just flushed my radiator, heater core and what hoses I could get at. I figured a little old coolant in the block mixed with majority new coolant I threw in won't hurt anything.
Make sure to use distilled water when mixing coolant!
Old Oct 23, 2012 | 01:22 PM
joecool911's Avatar
Can we get 3 gallons of water out of the cooling system without pulling the water pump to get 50% antifreeze solution in the cooling system?
How'd you flush your heater core?
Not all municipal water contains enough elements to require distilled water.
Last edited by joecool911; Oct 23, 2012 at 01:22 PM. Reason: Automerged Doublepost
Old Oct 23, 2012 | 01:28 PM
RAW's Avatar
RAW
As much as it sucks to pay money for water, I typically use a pre-mix coolant.
You probably can get 3 gal out easily. When I do a t-stat, or minor coolant repairs, I don't drain much coolant. I take the rad cap off, and run a 3/8" hose down to the bottom of the radiator through the rad cap. Then I siphon out as much coolant as I can into a pail, or water can of sorts.
Old Oct 23, 2012 | 02:08 PM
joecool911's Avatar
Whatcha want to bet that the antifreeze makers use nasty mud puddle water in their 50/50 mix? Scam like bottled water. Would be so much cheaper to use tap water in manufacturing process. Just my gut feeling.
Old Oct 23, 2012 | 04:16 PM
H.R.D's Avatar
I drain the coolant, then remove the T stat and take the top rad hose of the radiator and stick a hose into the radiator fill cap and turn the hose on. I then start the truck and let the water flow out of the top rad hose into a bucket or the ground, until it clears up. You could use some rad flush before this process too.
markv8993
Jun 21, 2015 12:24 AM
Dieseltech0593
Price Quote - Request A Price
May 7, 2015 08:14 PM
yz450f269
Mar 15, 2015 08:56 PM
LTreis702
Feb 14, 2015 12:52 PM
makuloco2000
Dec 7, 2014 11:15 AM
