air dog fuel issues
Old Oct 21, 2012 | 04:20 PM
olaus's Avatar
Default air dog fuel issues
Hey guys,
so bought a used Juice w/ Attitude and Installed it today. Immediately said I had 7 psi at idle so I turned the screw on my Airdog and got it to 15 psi idle. at wot it dropped to 0 quickly so I turned it more now it sets at 20 idle and drops to 1-2psi at wot at level 3. level 4 is 0psi quickly and at level 1 i stay around 4 psi.
I have a few questions.
1. I installed the sensor on the intake banjo at the VP. is that correct?
2. should there be this big of a difference in fuel? seems like the airdog was supposed to supply plenty of fuel to keep those numbers close. ( I don't have any other mods)
3. Will it hurt to have the pump running 25 psi @ idle to keep wot pressure above 7?
thanks
Nick
Old Oct 21, 2012 | 05:37 PM
RAW's Avatar
RAW
That is a good place for the sender. There shouldn't be that big of difference in fuel pressure. 25psi is a little high, I don't like to see over 21-22 at idle.
It may be your pressure regulating valve in the VP44.
https://www.dieselbombers.com/98-5-0...formation.html
Old Oct 21, 2012 | 10:34 PM
olaus's Avatar
Thanks for the link i was wondering about that. ill check it out asap. im guessing that isn't a part i can get at . Anyone have a part number?
Old Oct 22, 2012 | 07:30 AM
diesel life's Avatar
when we installed my airdog we had questioned where to put the sensor for the fuel pressure guage on my juice w/attitude so we called airdog and they told us that it is supposed to hook to the airdog pump. i run mine hooked into int and at idle im at 15psi and at wot it has never dropped below 10 psi.. just my 2 cents.... i believe i have the pictures on my phone if you would like to see them... all we did was lenghten the wires on the fuel guage to reach to the airdog
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
