swapping welded diff for ls/open diff
Old Oct 20, 2012 | 06:27 PM
smedley's Avatar
Default swapping welded diff for ls/open diff
can i pull out the welded one and put a factory limited slip or open diff back in with my shims back in and my backlash be ok or will it need to be set back up?
Old Oct 20, 2012 | 08:46 PM
wyodiesel92's Avatar
Need to make sure it's setup correctly whenever you change parts
Old Oct 21, 2012 | 11:09 AM
53Blocked's Avatar
Yeah make sure you re-set backlash after the swap. Even reusing the old stuff, backlash will not be the same now as it was origanally.
