should i bore or sleeve the block
Old Oct 19, 2012 | 11:38 PM
12vcummins11's Avatar
Default should i bore or sleeve the block
So my first cylindar is scarred up a little now the question is can you sleeve a cummins block.
Or should i just bore every hole .20 over?
Old Oct 20, 2012 | 07:41 AM
jmoore2006's Avatar
I would sleeve the block. I had a newer 06cr block I sleeved in 1/6 cylinders kept stock pistons and rings and 80k later with a smarty on 4 running the dog **** out of it I haven't had any issues with the sleeves. It will be the cheaper and most economical route.
Old Oct 20, 2012 | 08:19 AM
cummin_un_glued's Avatar
FormerVendor
I vote sleeve. We have done several that way with zero issues. Typically the sleeve material is stronger then the original block.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Oct 20, 2012 | 08:35 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i agree sleeve
Old Oct 20, 2012 | 09:08 AM
gyayo2012's Avatar
i was told you could not sleeve these blocks.. i guess you can!? where do you buy the new sleves from? I have an old block thats been sitting because of this same isue!! would love to build it back up!
Old Oct 20, 2012 | 09:10 AM
FormerVendor
We sleeve them all the time. Just talk to your local machine shop if they cant get a sleeve for it i would find a shop that can and use them instead.
Old Oct 22, 2012 | 08:14 AM
gyayo2012's Avatar
def good to know im gonna get on that for sure! was ready to throw this block in the Gabage
O'Brian
Feb 24, 2015 09:10 AM
CumminsCoalRoller24/7
Jan 29, 2015 08:37 AM
Jan 22, 2015 02:40 PM
Slim Whitey
Nov 8, 2014 09:41 PM
Oct 8, 2014 11:50 AM
