Brake problems
Old Oct 19, 2012 | 09:56 PM
vicvega's Avatar
Default Brake problems
I wondered if anyone has any ideas on my brake. Issues. My truck stops fine some times, then I can't oust the pedal down then, I push it to the floor and barely stop. Not by choice haha. I checked the vacuumed its steady at idle at 25. I don't know what to try next. It has fluid. I've read it is an option to just get an aftermarket kit if a guy can afford it. Any help would be great thanks
Old Oct 19, 2012 | 10:31 PM
bladeyamaha's Avatar
Might the booster or master cylinder. Not an expert on which. May not hurt to replace both, but prolly not necessary. Sounds like the master cylinder may be out. Check the rear brake cylinders for leaking too. Check the calipers. Check your depth of shoes and brake pads.
Old Oct 19, 2012 | 10:40 PM
Ltk's Avatar
Ltk
Mine did the same, but pedal got very stiff and couldnt stop. I replaced my abs sensor which had been chewed by my dogs and it stopped it. Could be your hydro or vacuum booster, whichever one your truck has get it checked out
Old Oct 19, 2012 | 11:50 PM
1stgenblowingsmoke's Avatar
Go into your cab pop the glove box out by pushing down on the tabs holding it from folding out to far. In behind the glovebox is the abs model unplug it n see if that fixes it. Mine randomly did that one day going down a hill with a intersection at the bottom. Unplugged it n my brakes had never worked so good since I got the truck till I unplugged the ABS module.
Old Oct 20, 2012 | 11:31 AM
vicvega's Avatar
Rite on thank you I will give it a try
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
russellflemister
Mar 18, 2015 09:08 PM
yams
Nov 29, 2014 09:25 PM
