Injector Info Appreciated
Old Oct 18, 2012 | 11:04 AM
53Blocked's Avatar
Default Injector Info Appreciated
I know this has been posted a thousand times probably but I would like some new thoughts on this subject. Mods are in my signature. I am looking to get a set of injectors finally. I would like to be between 75 and 150 HP injectors UNLESS you think that is too much for my setup. I really dont want to have to upgrade anything else yet so whats in my sig is all that will be supporting the injector mod. I would like to get as big as I can reliably handle so that I spend the money and dont wish I had a bigger set (I barely got the money to buy this set let alone buying another bigger set down the road). The truck is my play toy. I drive it to work alot during the week, take it muddin occasionally on the weekends and take it out skinnin sometimes I rarely tow with it and when I do its like 8-10K max. I am looking for a brand name reliable good injector. Thanks for any help.
Old Oct 18, 2012 | 11:50 AM
RAW's Avatar
RAW
I've been very happy with my Injectors from Diesel Dawgs. I had a set of 65's, and now have 150's. I can't say I have tried other brands to compare them, but they seem to be working great so far. Reasonably priced as well. As for size, I was going to say 150's, and do a turbo upgrade down the road. With mudding in the list of things to do, I'm not sure if that big is a good idea. It would be very easy to get out of EGT control while having fun, or getting in a tight spot. If you can cotrol your right foot until a better turbo, then 150's for sure. Otherwise a set of 75's will make a noticeable difference.
Old Oct 18, 2012 | 12:18 PM
53Blocked's Avatar
I get pretty hammer happy in the mud if ya no what i mean but I can keep her out of the mud and be a more mature respectful driver if need be. I would like to go 150's if you think I would be alright with them? And eventually get a bigger turbo. I am trying to avoid studding though too just because of the amount of time to do it and money. Also how hard are the injectors to do on these trucks? I am a John Deere mechanic and have done injectors on more than one occassion on a deere motor but have never even had the valve cover off of my truck
Old Oct 18, 2012 | 12:37 PM
RAW's Avatar
RAW
Probably easier than any Deere engine, except the 6068's with pencil injectors. I'm a 9 year Deere guy, both Ag and Construction. I'm trying to think what they would be like, and the closest would be a 6081 with the early HPCR, less the electronics. Getting the rocker cover off, and #6 line off are the trickiest parts. After that, it's pretty simple. 3 hours for the first time, maybe.
Old Oct 18, 2012 | 06:59 PM
53Blocked's Avatar
Thanks for all the help. Do I need any special tools for the injector job? and you think 150s be okay with the fass 95gph? thats my main concern i run 18psi idle and 15psi WOT with chip all the way up.
Old Oct 18, 2012 | 07:48 PM
zach2's Avatar
I put a set in last year for the first time. Like said, the #6 was the most difficult as I couldnt get my valve cover all the way off. Still, no special tools. I believe I used one of the intake elbow bolts threaded into the top of the injectors to use as a puller. I slid the open end of a wrench under the head of the bolt and used the nearest rocker arm as leverage to pop the injector out. Wordy, but I hope that helps!
Old Oct 18, 2012 | 08:15 PM
53Blocked's Avatar
Thanks for the tips fellas. I am leaning towards the 125 HP diesel dawgs so they aint to much but still fairly big.
Old Oct 18, 2012 | 08:21 PM
RAW's Avatar
RAW
They will do you well. There are a few write ups on here about replacing injectors, and it can also be found on YouTube.
Old Oct 18, 2012 | 08:53 PM
Dodgemanstan's Avatar
go 75 or 100 then get studs then turbo...
Old Oct 18, 2012 | 09:04 PM
chad83181's Avatar
Love my 150's from Luke @ DIESEL DAWGS as well. Like stated above easy with right foot until a turbo.
