Building My IDI
Old Oct 17, 2012 | 02:02 PM
rmaseda22's Avatar
Default Building My IDI
So i have a 7.3 IDI non turbo and i am rebuilding my motor but i want to know the best head studs to use as well as injectors and turbo. i pretty much want to make the motor bulletproof with more power and torque but still be able to roll some serious coal.
Old Nov 8, 2012 | 04:50 AM
billiard's Avatar
id say arp headstuds are the way to go. im not sure where to find them but you can run moose injectors and injection pump from what ive heard. he matches the injectors to the pump
Old Nov 8, 2012 | 08:44 AM
blacksmokeaintbroke's Avatar
keep us posted on the build,what you use,and what horsepower you end up with.
Old Nov 8, 2012 | 12:28 PM
rmaseda22's Avatar
will do boss. ill upload some pictures of my rig and what it looks like now. and thank you billiard for the info. im going to look into that. as of right now im doing a solid axle swap in her with 4.10 gears.
Old Nov 11, 2012 | 05:53 PM
fordidipower's Avatar
i have a turbo bmw and i didnt want to pay for headstuds from arp and looked online and all the european dudes use metric blues wich are no tapper non stretch and they work great. so you could get bolts that are the same size and thread pattern as stock and wont stretch from an online high grade bolt dealer. save loads of money.
Old Nov 22, 2012 | 10:43 AM
Kalashnikov's Avatar
I see you're from MA. I'm out in sothern worcester county
I would just buy BB injectors and a rebuilt turbo pump and crank up the fuel screw. The moose pump and injectors are worth the money IMO. Might as well stroke it if you're gonna drop that kind of cash.
Old Nov 24, 2012 | 07:48 PM
rmaseda22's Avatar
yea im from the cape @Kalashnikov. and ive heard bb code injectors are good for the IDI's if you want to upgrade them. if any of you guys know, whats the difference between stock and bb code other than the spray pattern?
Old Nov 25, 2012 | 12:06 AM
I think pop pressure was higher on BBs.
Old Jun 22, 2013 | 10:45 PM
daves93f250's Avatar
i think the moose pump's and injectors are on sale at oilburners some guy sells them there.
Old Jun 23, 2013 | 04:09 PM
4x4manonbroke's Avatar
Well the issue your gonna run into no matter what u attempt to run is cylinder temp and not being able to run much for boost ..... unfortunately ur limited by tue design of the engine ...... I do wish tuere was a way to make gobbs of power with these ..like a 12valve ..... but the design is good .... just not with a bunch of boost ..... I have BB injectors and my truck runs awesome .. the only issue is interior noise
wildhorsemfg
Show And Tell
Sep 20, 2015 11:26 AM
88 f350 7.3 idi
Aug 20, 2015 09:18 AM
Toms73
Mar 23, 2015 08:31 PM
g.logistics
9
Nov 22, 2014 08:54 AM
Browe347
Sep 30, 2014 11:35 PM
