TPS Question
Old Oct 15, 2012 | 08:31 PM
cpberry1's Avatar
Default TPS Question
A new-to-me '93 D250 auto with 306,000 miles on it - cranks right up and sounds great. No automatic overdrive though (overdrive works, just have to use a grounding switch bypassing the PCM) and I'm trying to get it working automatically again. Jumped the usuals - tranny temp, etc and still no help. I have noticed that the TPS sensor on this truck is 180 degrees rotated to the others I've seen - the wires come out on the driver's side, not the valve cover side like most. Would this alignment have anything to do with getting an appropriate signal out to the PCM? The voltages check out fine on it but I'm not 100% sure whether the positioning of the sensor would matter - never have looked at one of these out of the truck so I'm not exactly sure what's going on down under it.
Thanks for the help,
Patrick
1999 4bt NV4500 Dakota
1993 automatic D250
Old Oct 18, 2012 | 06:22 PM
cpberry1's Avatar
Crickets...
Old Oct 26, 2012 | 02:46 AM
jwirth's Avatar
Never seen a TPS on backwards like yours. It's notched so not really sure how it could be on backwards. Try seeing if it will mount 180 with the wires facing the valve covers
Old Oct 26, 2012 | 10:17 AM
cpberry1's Avatar
Okay, thanks for the reply!
Patrick
Seann12
Jun 17, 2015 10:40 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
Genghiscarl
Oct 27, 2014 10:19 AM
