Fixing a fuel shut off solenoid.
Old Oct 15, 2012 | 01:16 PM
bladeyamaha's Avatar
Default Fixing a fuel shut off solenoid.
Figured out how to fix a fuel shut off solenoid with some pics a link confirming this and of course Josh pointing out the link to me! I'll post pics as soon as I can, tweaking right now and will post pics ASAP. I basically tore off and drilled out the stock rubber on the "stopper" and "plunger", so, I also tapped it for a screw and put a modified valve cover grommet in and will have to remodify one so it will fit better, like I stated pics will follow so all can save anywhere from $80 to $120 and reuse their Bosch one.
Fix your fuel cut-off solenoid - Dodge Diesel - Diesel Truck Resource Forums
Pics of my own and my fix to follow tomorrow or tonight, whichever may occur!
Fixed it, but with epoxy, the screw kept the grommet from sealing so, and did not have enough grommet to go around to play with so I had to epoxy it in place, thinking now to use the manual kill lever to stop the engine though, and use this port as a larger fuel inlet port.
Last edited by bladeyamaha; Oct 15, 2012 at 01:16 PM. Reason: Automerged Doublepost
Old Oct 15, 2012 | 06:04 PM
BC847's Avatar
There are plenty of $10 FSS available from many VW TDI parts houses that work just fine.
Personally, I've had very good, reliable results with simply sanding down the original plunger tip.
Old Oct 15, 2012 | 07:12 PM
Mine had too big a chunk missing to do that with unfortunately, I tried that first. LOL
Old Oct 15, 2012 | 08:49 PM
1stgenblowingsmoke's Avatar
Brandon, BC847 is the one who made that link on dtr.
Old Oct 20, 2012 | 02:41 AM
jwirth's Avatar
I had a friend machine me an all metal one. It worked in my old pump but I have a new II pump and I'm not opening it up until after the warranty is up.
Old Oct 20, 2012 | 01:35 PM
OK?
The link is a first option, what's the big deal?
Last edited by bladeyamaha; Oct 20, 2012 at 01:35 PM. Reason: Automerged Doublepost
Old Oct 20, 2012 | 05:11 PM
Originally Posted by bladeyamaha
OK?
I did it on mine n ran it for 8k km with no problems.
Old Oct 20, 2012 | 09:56 PM
I wasn't saying my idea was better, I was just pointing out ways to fix the damn problem.
Old Oct 21, 2012 | 08:51 AM
92betsy's Avatar
If you really want to fix it just get bigger injectors, and then you won't have back pressure from little stock injectors blowing your plunger. Just a thought.
Old Oct 21, 2012 | 04:24 PM
That's in the plans, LOL!
camp9
Mar 25, 2017 07:40 AM
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
