HRVP44 worth it?
Old Oct 14, 2012 | 06:07 PM
noseamum's Avatar
Default HRVP44 worth it?
Hey, my vp is toast ant I need to replace it.So I am considering buying a hotrod vp.
I have 125`s and ADR to beat on my super B, so wondering if a HR will be way too smokey?
Planning on twins later.
The truck is my dd.
Old Oct 15, 2012 | 12:20 AM
Bryce's Avatar
I don't think the hot rod will make any more smoke. I'm just an amature but I think its the bigger injectors coupled with not enough air that makes the smoke. Putting twins on you'll need the hot rod.
Old Oct 15, 2012 | 12:46 AM
cummin_un_glued's Avatar
FormerVendor
Hot rod pumps dont like havin their wires tapped. Your upper settings on your ADR will be useless. It will make a little more power but not alot more. No where near the 100hp because all a hrvp is made of is a SO pump with an HO brain. A standard SO pump will make more power in the end.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Oct 15, 2012 | 02:55 AM
CrazyDog's Avatar
X2, save your money and get a nice quality built SO pump. SO pumps can be taken over 600hp.
Old Oct 15, 2012 | 03:02 AM
SO pump is best way to go bud
Luke
Old Oct 15, 2012 | 04:01 AM
noseamum's Avatar
Thanx SO it is
Old Oct 15, 2012 | 10:23 AM
BarryB's Avatar
Pardon my ignorance, Does SO stand for stock output, and HO high output?
Old Oct 15, 2012 | 11:59 AM
RAW's Avatar
RAW
You are correct. The 6 speed trucks came with HO pumps.
Old Oct 15, 2012 | 01:38 PM
Bryce's Avatar
Can a HO pump be used with a 5sp or auto? Or will it only work on a 6sp? If it will work would it have the same problem that cummin_un_glued mentioned with the hr
Old Oct 15, 2012 | 05:05 PM
noseamum's Avatar
So if I buy a SO and regret it I can just get the HO electrics for it and make a HR???Sounds to easy?But cool if it works
