Starter troubles 94 Chevy K2500 6.5 turbo
Old Oct 14, 2012 | 08:29 AM
cattails33's Avatar
mad Starter troubles 94 Chevy K2500 6.5 turbo
Can use some help on a starter problem I'm having with my vehicle. Turning the key to start and no response to the starter, but the gages react on the dash. Put a volt meter to the solenoid 'S' terminal and had someone turn the key to start and no current to that wire and all lights and accessories are working properly. The battery wires to the battery both have voltage 13.3 even past the fuse link. The purple wire is dead.
Any help is appreciated to guide me on a check of the system. Batteries are new and I recently changed the alternator because of a bad bearing in the alternator.
Does anyone know where the purple wire is attached to and how to check the ignition switch and neutual safety switch? Car is eguipped with a Chapman aftermarket alarm system that I have reset several times and seem to be ok.
Old Oct 14, 2012 | 12:36 PM
Cumberland6.5td's Avatar
Try to start it in neutral. Other than that check your fuses and relays. Could be the ignition switch. Just some ideas
Original_big_rod
Aug 21, 2016 02:30 PM
Brclouse
Nov 18, 2015 08:44 AM
Chevy6.5/2500hd
Jun 21, 2015 02:37 AM
timmyd
Jun 8, 2015 11:35 PM
Snoobly
Dec 11, 2014 11:59 AM
