Fuel Pressure sensor location??
Old Oct 13, 2012 | 05:38 PM
Cummins821's Avatar
Default Fuel Pressure sensor location??
Hi, I'm in the middle of installing my glowshift fuel pressure gauge sensor and was wondering where is the best place to locate it. Glowshift says under the fuel filter housing but I have a FASS fuel system, will I still get a reading at the fuel filter housing? I opened it up and there wasnt much fuel in there and seemed dry, is this stock fuel filter housing serving no purpose now? Any help would be greatly appreciated.
Old Oct 13, 2012 | 06:16 PM
Bryce's Avatar
If it is a fass with filters the factory filter is not used and you put the sensor in the fuel line between the fass and injection pump. If it is fass ddrp then you install it between factory fuel filter housing and injection pump.
Old Oct 13, 2012 | 06:21 PM
Cummins821's Avatar
okay it's a fass 95 with the filters, is there anwhere on the lift pump the sensor could be installed or only on the line itself between the lift pump and injection pump. Appreciate your reply. Thanks!
Old Oct 13, 2012 | 08:05 PM
Bryce's Avatar
No. No where on the pump itself. You can put it right beside the pump if you want to but it still needs to be between the pump/filters and the injection pump. That way when pressure starts to drop you know its time to change filters.
Old Oct 13, 2012 | 08:17 PM
Cummins821's Avatar
Okay I will thanks. I would assume some kind of T device would be needed and run some sort of fuel rated line to the sensor mounted on the fender or firewall to reduce vibrations? Any better way?
Old Oct 13, 2012 | 08:30 PM
Bryce's Avatar
Now if you're looking for some where to put the sensor without cutting lines and installing adapters, there should be a 1/8" npt port where the fuel line goes into the injection pump (unless the banjo line was replaced when the fass was installed). You can put the sensor there but having the sensor next to the ip can cause the "water hammer" effect. You will need this Autometer snubber (AUTOMETER FUEL PRESSURE SNUBBER RESTRICTOR CUMMINS | eBay) or you can make your own. Check this link out to learn more about water hammer and making your own snubber. Mopar1973Man's Dodge Cummins Articles - Fuel Pressure Gauge And Water Hammer Effects
Yes you would have to buy a T adapter to cut the lines and install the sensor.
You need to fill out your signature with all the info on your truck. Like 4x4, auto or manual, Fass 95, ect. It will help us answer your questions. Top left corner click on user cp then edit sig.
Old Oct 14, 2012 | 12:07 PM
Cummins821's Avatar
thanks again for the all they help!glowshift sent me a snubber valve when I ordered the gauge so I believe that will work. When the FASS was installed they put it from the lift pump right to the VP. So that banjo line was by passed. My only question is what type of tubing or line can I run from the T to the sensor?
Old Oct 14, 2012 | 12:46 PM
Bryce's Avatar
Just go into your parts store and ask them for fuel rated hose in whatever length you need.
Old Oct 14, 2012 | 06:03 PM
Cummins821's Avatar
thanks for all your help, Bryce!
Old Oct 14, 2012 | 06:52 PM
Bryce's Avatar
You're welcome. Thats what this forum is for. When you cut your line and install the sensor you are going to get air in the system. Before you try and start it, bump the starter and let the lift pump run. Do this 5 times. If it won't start after doing this you will need to bleed the injector lines. If you need any more help just let me know.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
