low voltage from ecm
Old Oct 13, 2012 | 05:23 PM
lauber_03's Avatar
Default low voltage from ecm
Does anyone know how much voltage should come from the ecm to the fuel lift pump relay? Been getting 0230 code cause my lift pump is losing power. traced it back to the two wire connector, its hit and miss getting power. when lift pump has no power that wire is putting out maybe .03 volts. gonna take the ecm off tomorrow and test wires, look for corrosion etc
Old Oct 14, 2012 | 12:40 AM
blacksally's Avatar
my truck did the same thing saying low voltage to lift pump it was a ground wire on pass side going to battery was cracked on battery post
Old Oct 14, 2012 | 12:45 PM
lauber_03's Avatar
i've checked all my grounds. they are all .2 or .3 i'm thinking maybe my ecm is bad but its not throwing any codes other then sometimes it loses power to lift pump relay, so i get a p0230. i checked the ground wire and yellow w/ white striped wire, it had 27.25 ohms through the ecm......not sure if thats bad or not.
john grossman
10
Jan 12, 2019 08:58 PM
Saams69
Jul 20, 2015 11:21 PM
robbyS
Apr 16, 2015 02:22 PM
scottxmorris
8
Mar 4, 2015 10:22 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
