Rocker Panel Treatment
Old Oct 13, 2012 | 10:41 AM
joecool911's Avatar
Default Rocker Panel Treatment
My rocker panels have a few small blemishes (dents). Nothing significant and the paint is ok. I've been struggling with ideas to cover these up, rather than fixing and repainting. My ideas are;
Paint the panels a contrasting color maybe even hammerite paint. Camo decal treatment. Rino liner. Chrome accent panels.
I have not been enthused about any of my ideas yet. Any other suggestions here?
Old Oct 13, 2012 | 06:04 PM
dieseldude848's Avatar
it would cost some coin, but id line-x from the lower half of the doors down.
Old Oct 14, 2012 | 09:30 PM
RollinCoal99's Avatar
x2 on the line x it will look good and protect from rust and rocks chipping the paint
Old Oct 14, 2012 | 09:32 PM
tiremann9669's Avatar
Isn't line x about the same as rhino liner
Old Oct 14, 2012 | 10:04 PM
Ltk's Avatar
Ltk
yea it is same concept, but line-x tends to be not as globby and rough and wont fade.. or so they say...
Old Oct 15, 2012 | 08:42 AM
blacksally's Avatar
i did a liner on my 99 powerstroke since i took the side moldings off and it peeled the paint i just taped it off and used a DA with 80 grit and got it sanded down then did a coat then let it tack uop then other about 4 times or so it worked good looksed good and lasted even in winter it held up good
Old Oct 15, 2012 | 09:21 AM
RAW's Avatar
RAW
I used Dupli-Color on mine, and I don't suggest it. It "globs" pretty bad and holds a lot of dirt. It is also water based, making it tricky to apply, and needs to thouraly cure before seeing any moisture (rain, car wash, etc.).
Old Oct 15, 2012 | 06:07 PM
shellinger's Avatar
I have been to a shop that sprayed line x and rhino liner. the line x is much harder and much less flexible. and like every one else said line x is a bit smoother than the rhino liner.
Old Oct 15, 2012 | 07:01 PM
blacksally's Avatar
i got the dupli color stuff to it said it was textered it wasnt really thin i used hurcaliner worked good
Old Oct 15, 2012 | 09:20 PM
joecool911's Avatar
Sounds like I've covered the options you guys have suggested. I'm leaning towards Hammerite paint in grey. Very tough hammered finish. And pretty cheap. Can re-coat down the road as necessary.
The other thing I thought would look cool is a decal material that is black diamond plate pattern.
Last edited by joecool911; Oct 15, 2012 at 09:20 PM. Reason: Automerged Doublepost
