LOW engine temp
Problem just started yesterday... my truck wont go up to normal engine temp. Driving it will onl y see 150 degrees and it drops. is my t stat stuck open.? Outside temp is 40 degrees
Very easy to replace. If you follow the upper radiator hose to the engine, it is under the cast adapter to the engine. Drain a gallon of coolant out, three bolts, change the t-stat, reverse the disassembly order.
burndiesel
10
Feb 7, 2023 01:15 AM
JDurks2
16
Jun 7, 2015 08:57 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
