auto trans cooler lines
Old Oct 12, 2012 | 07:59 PM
cumminspwrram59's Avatar
Default auto trans cooler lines
my 99 i noticed the other day there was a wet spot underneath it. it has been sitting on concrete for awhile as it doesnt get run everyday. i pulled it in garage and changed oil and whatnot and found the trans cooler lines from the engine oil cooler had rubbed a hole where the plastic clamp went around the lines. ive checked most of the local parts stores around here and they could possibly get 1 but not both. has anyone else ever had these lines go bad and if so where did you get them. i called dodge and gave them the vin of my truck and he said i would have to come in to see if they were right but the dealerships parts dept. is only open till 5 in the evening and closed on weekends. could i cut out the bad section of the lines and replace them with rubber hose? thanks in advance for the help
Old Oct 12, 2012 | 10:18 PM
Smarty=Cummins's Avatar
Mine rubbed a hole in it to it was the long straight one the line that hooked in on the back of the tranny. Went to dodge dealership ordered it cost me 50 dollars.
Old Oct 13, 2012 | 02:47 PM
01quadcab's Avatar
I just went with rubber lines the good stuff rated for oil coolers and transmission fluid been that way for years no issues
Old Oct 13, 2012 | 03:12 PM
did you just take the bad section out or replace the whole thing?
kydieseltech
May 28, 2015 05:00 AM
apehangerjoe
Mar 26, 2015 03:01 AM
Mayhem
Price Quote - Request A Price
Nov 22, 2014 03:04 PM
countryboy040993
22
Nov 12, 2014 11:25 AM
FlyingDutcman
Oct 28, 2014 04:56 PM
