Fuel Screw....
Old Oct 12, 2012 | 06:35 PM
1993cummins's Avatar
Default Fuel Screw....
If I was to turn up my fuel screw on my 1993 w250 do I also have to do other things or is it fine to just simply .. remove the cap..remove the bolt , turn the screw and put the bolt back on ? ... is that all you do ? thanks ....
NOT because I want it smoking whenever I want it , but because I think it is back off all the way from the previous owner since he towed alot !
Old Oct 12, 2012 | 06:54 PM
bladeyamaha's Avatar
Old Oct 13, 2012 | 10:44 AM
willyslick's Avatar
my throttle is real touchy after the gov spring mod.wants to run away when advanceing throttle only alittle.turned fuel screw down as much as i could but will stall before i can get it where it needs to be.im on the 2nd notch on index where it is supposed to be stock.
do you think i need to advance to 3rd mark on index?
ps i added 75 hp injectors and new custom turbo.
wake up out there i need some help!
Last edited by willyslick; Oct 13, 2012 at 10:44 AM. Reason: Automerged Doublepost
Old Oct 13, 2012 | 10:47 AM
I dont know man , I am fairly new to the diesel world ... but after all ive been looking into i think ill leave my trucks fuel pin stock so nothing gets screwed up.....Hopefully you find your problem .. I would just keep playing with it until you find the spot you need it( just remember keep a towel or something in-case in actually does runaway you can throw it on the turbo
Old Oct 13, 2012 | 11:03 AM
willyslick's Avatar
thanks,but you dont want to throw a towel on the turbo.stick to a board 2 *6
anybody else can help?
Last edited by willyslick; Oct 13, 2012 at 11:03 AM. Reason: Automerged Doublepost
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
