Dodge crappin out...
Old Oct 11, 2012 | 02:11 PM
scottmorgan's Avatar
Default Dodge crappin out...
i have a 2001.5 dodge ram with the 5.9 cummins. the rest is at the bottom
i was timeing my 351 vgt turbo by removing the electronics and moving the arm and then putting them on. i changed the position several times and on my 4th or 5th try i fired up the truck pulled it out of the garage and it was running funnny.
i have found out i have no turbo operation any more
and i have 3 codes
P1689 - not comunication between ecm and fuel pump
p02** - low bost
P16** - Companion Code(states there is a code on the ecm)
** i do not remeber the exact numbers.
my truck ran funny would only hit 1400 rmp was in limp mode getting there.
i cleared the code and it runs fine. the code came back after about 130min of driving and the truck still runs fine. only issue the vgt turbo still does not work.
i am cleaning all grounds i can find and cheacking relays but i have no clue were to go if that does not work.
please let me know if you have any knowledge on what to do.
Old Oct 11, 2012 | 05:35 PM
RanchhandTCR's Avatar
Ohh, I cant help you sorry, maybe try contacting Rawwilliams or HRD I think both of them have done some research on the VGT swap can can lead to helping you fix the gremlin hiding somewhere..
Old Oct 11, 2012 | 06:34 PM
Ltk's Avatar
Ltk
vcustoms has done the VGT swap also. one of those 3 should know
Old Oct 11, 2012 | 08:00 PM
Yes I completly forgot he has done that too!! Its a shame too, hes the one that gave me my Colorado Cummins Flag..
Old Oct 11, 2012 | 08:48 PM
Ltk's Avatar
Ltk
haha that is a shame!
Old Oct 11, 2012 | 09:45 PM
yeah but i think the vgt turbo is not working because of the fuel pump not comunicating to the ecm. the turbo runns of the amount of fuel being applied and if the truck dont know how would the turbo. i need to get rid of my truck not comunicating with my ecm first. the bgt turbo is the least of my worries.
Old Oct 11, 2012 | 11:45 PM
Im trying to think I ran accross a good article about this issue Im trying to find it, If I remeber right it was something simple
To ask a simple question did you every check your relays?
Last edited by RanchhandTCR; Oct 11, 2012 at 11:45 PM. Reason: Automerged Doublepost
Old Oct 12, 2012 | 01:38 PM
yeah i did but i can not find a fuse for it. just the relay. so im going to check all my relays and fuses again. and i have re done all the grounds i could find. if its like the old chevys when the water temp sencer gets fucked up it causes the hole system to go heywire. i let out some fluid while timeing my vgt turbo. It could have messed with the temp sencor on my truck. ill replace that and pray to god it works. its a long shot but if it works ill be supper happy!
Old Oct 12, 2012 | 06:19 PM
I kinda doubt it but hey if its works
Old Oct 15, 2012 | 01:41 PM
well lets just say that stab in the dark was a no go.... still not finding anything... could it be my pump if my truckis runnig just fine?
