Why does it take so long for my truck to warm up?
Old Oct 11, 2012 | 06:57 AM
Fullpull's Avatar
Default Why does it take so long for my truck to warm up?
My 2006 F250 takes forever to warm up. And won't until I start driving. The engine light came on. It throws blue smoke out the pipe and doesn't wanna run over 2,000 rpms. What could cause this?
Old Oct 12, 2012 | 08:40 AM
Mdub707's Avatar
Well there is 15 quarts of oil it's trying to heat up there. and 7 gallons of coolant.
Have you tried reading codes to see if anything comes up? How old are your batteries? If you have no codes, I'd start with a load test on the batteries (places like advanced auto etc do this for free) then test the FICM. You can find the test procedure at the top of the 6.0 page.
Old Oct 12, 2012 | 10:13 PM
Diesel_Daddy6.0's Avatar
The vanes on the turbo won't cycle until the engine is up to operating temp, so that could be part of your RPM issue. As for the long warmup, make sure your thermostat isn't stuck open. The reason it starts warming up once you're driving is because the engine has a load on it and has to work harder (hence why my buddy's truck warms up faster than mine in the morning even though we both have high idle engaged, his being an automatic locks up the convertor putting resistance on the engine) and yours has to work a LOT harder if the turbo isn't cycling yet.
Old Oct 15, 2012 | 08:16 AM
Fullpull's Avatar
Ok, the computer says egr and something else. I'll call my buddy and ask him what the other was.
Old Oct 15, 2012 | 10:52 AM
Mdub707's Avatar
If you have the factory upfitter switches (four switches down by the brake controller) you can do a 10 minute mod with one or two wire crimps and get yourself the high idle. So you put the parking brake on, flip the upfitter you've wired to, and it will jump to 1200 rpms and lock the converter to warm it up faster, and keep it warm. These trucks really shouldn't be idled for long times without it.
Can we get more info about the truck? Is it stock? Egr valve probably should be pulled and cleaned, that could the cause of your issues right there. Let us know what the other code is.
Old Oct 15, 2012 | 03:36 PM
Fullpull's Avatar
Ya I'm sorry. 2006 4door long wheel base 4x4. It's completely stock except the air cleaner. It has a K&N air box on it designed for the truck. That's it. What do I wire into the upfitter, and which upfitter because some hold more power than others? I will pull the egr and clean it. The batteries are not even a year old. Who can test the FICM? Sorry I'm a nearby to the newer style diesels.
U1900 controller area network communication bus, this is what the computer is sayin besides the egr.
Old Oct 16, 2012 | 07:49 AM
Mdub707's Avatar
Just do a Google search for "6.0 powerstroke high idle mod" you will get tons of results including YouTube vids. Very easy to do. FYI, upfitter 1 and 2 are 30 amp, and upfitter 3 and 4 are 10 amp.
What are you reading codes with? Did you try clearing it and driving it to see if they come back. I would expect a ton of issues if you had a U1900, including bouncing speedo, erratic engine idle possibly, other gauges not functioning right...
https://www.dieselbombers.com/diesel...ode-u1900.html
Old Oct 16, 2012 | 08:21 AM
Fullpull's Avatar
Ok, I read it with an Auto Scanner from Advance Auto Parts. No I didn't think about that, I figured if the computer was goin out then I would have major problems. But non of that is happening. I appreciate all the help
Old Oct 16, 2012 | 09:07 AM
Mdub707's Avatar
Try clearing that code and see if it returns. It may just have been stored in there from a previous incident.
Old Oct 16, 2012 | 01:32 PM
Fullpull's Avatar
Ok, it's only got 155,000 miles
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
cooler364
Mar 26, 2015 10:58 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
