Track Bar
Old Mar 10, 2008 | 09:31 PM
wes's Avatar
wes
Default Track Bar
I installed a new adjustable track bar yesterday. Now my steering wheel is not aligned and I still have the death wobble. Thanks for any help.
Old Mar 10, 2008 | 09:40 PM
Uncle Bubba's Avatar
Be sure to fill out your signature so we know what were talkin about here.
Are you sure you the axle centered to the frame with the trac bar and are all the bolts tightened down. If your like me you better double check cause you'll find at least one hangin loose. What kind of bar is it.
Old Mar 11, 2008 | 03:15 AM
I-6DZL's Avatar
Check your tie rod ends, and ball joints too, they can all cause problems!
Old Mar 11, 2008 | 07:17 AM
GRI's Avatar
GRI
your wheel shouldnt be off center by just changing the trac bar (unless you lifted it at the same time)
it sounds like the axle isnt centered.
Old Mar 11, 2008 | 07:57 AM
wes's Avatar
wes
How do you center the axle? Everything is tight. Its a Thuren track bar.
Old Mar 11, 2008 | 08:24 AM
GRI's Avatar
GRI
you need to measure from the axle to the frame. pick a spot on the axle that is flat and the same on both sides. run a straight edge up to it so you can measure the straight edge to the frame. then do the same on both sides.
Old Mar 24, 2008 | 06:50 PM
DB Admin's Avatar
Banned
Any Word on this ?
Old Apr 4, 2008 | 09:06 AM
Johnny Cetane's Avatar
Did you get this one finished, Wes?
Old Apr 10, 2008 | 03:59 PM
It's been a month. I'm closing the thread.
mark402001
Tire, Wheel & Suspension
Jan 18, 2015 03:17 PM
Nov 11, 2014 06:00 PM
Nov 11, 2014 02:30 PM
12vbomber
Nov 11, 2014 10:58 AM
motormayhem
Nov 1, 2014 01:24 PM
