Fuel delivery problems- need some help
Old Oct 10, 2012 | 12:45 PM
Dieselobermaschinist's Avatar
Default Fuel delivery problems- need some help
My '92 D250 had an after market electric lift pump failure lat week. I replaced the failed pump and now I can't get the truck to run. I bled the injectors, per the video posted on here, the truck started and idled but only with the pedal to the floor. By then my battery was toast. I put the charger on it two days ago, got fully charged, I went out this morning to start it and now it won't even run... Turns over great, but still not getting enough fuel, I believe. Air still trapped in the lines? Something with the injector pump?
Old Oct 10, 2012 | 01:40 PM
1stgenblowingsmoke's Avatar
Keep bleeding till you get solid fuel coming out the injector lines. You may have bleed all 6 a couple times. Did you bleed fuel at the fuel filter?
Old Oct 10, 2012 | 03:33 PM
The water separator, near the new lift pump, has a prime/pump on top of it. I primed the new pump and saw no bubbles left in the separator sight window. I'll try bleeding the injectors again.
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
