Oil Pressure went to 0 at idle
Old Oct 10, 2012 | 09:15 AM
RandoH's Avatar
Default Oil Pressure went to 0 at idle
Hey guys
Started the 2000 5.9 this morning and all was fine. The oil pressure showed fine so as it warmed up I went back in the house. I came out and the oil pressure showed 0 and the check gauges light was on. I shut it down and checked the oil. It was ok. There was no abnormal noise. I pulled the filled cap and all looks wet up top. Sound like a sending unit? Im reading these are pretty common and looks like Cummins is the place to buy it, Stealership is like 250! ANy help would be appreciated! Thanks!
Old Oct 10, 2012 | 09:21 AM
1999stroker's Avatar
Id try the sending unit first then go from there.
Sent from my DROID BIONIC
Old Oct 10, 2012 | 09:40 AM
RandoH's Avatar
Do you or anyone know if Cummins part #4921511 will work?
Old Oct 10, 2012 | 10:14 AM
RAW's Avatar
RAW
This is a lot cheaper:
'98.5-'02 Dodge Turbo Diesel Oil Pressure Sensor-Geno's Garage
Also, check to see if you have a Cummins dealer in the area. I know I can get genuine Cummins parts cheaper from a truck (semi) dealer than the stealership.
Old Oct 10, 2012 | 11:26 AM
RandoH's Avatar
Thanks guys. I went off and left my serial number at home. Ill have to get that off the truck or out of the book and give them a call. They gave me a part # but wanted the serial number to confirm. Sounds like this is a pretty common occurance.
Old Oct 10, 2012 | 11:28 AM
H.R.D's Avatar
Yep senors are a wear part, so you will have to replace them from time to time.
Old Oct 10, 2012 | 02:21 PM
RandoH's Avatar
Thanks , Yeah just sucks when its the one for oil pressure, about gave me a heart attack! This is my first diesel which I have had it awhile but still learning. Im checking with my local Cummins guy to see what he can do for one.
Old Oct 10, 2012 | 02:25 PM
01quadcab's Avatar
mine is stuck on reading 40 psi it never moves
Old Oct 10, 2012 | 09:04 PM
Bryce's Avatar
To ease your mind and be sure its the sending unit, go to orielly's and get a cheap manual oil pressure gauge. I picked one up for $18. There is a port on top of the oil filter you can hook it up to.
Old Oct 11, 2012 | 08:29 AM
Ed9824v's Avatar
Mine went out and oil pr. dropped to zero. I don't have the number now but the price was far cheaper at the cummins dealer the dodge people wanted to sell me a different part with some adapter for twice the price. but I think I paid about $65 dollars. the info is on my dead computer.
Durtyd09
Nov 11, 2015 01:43 PM
soco
Jul 27, 2015 06:06 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
