3 cylinder high idle
Old Oct 9, 2012 | 10:21 PM
scrappiron68's Avatar
Default 3 cylinder high idle
I have a 2002 cummins with the nv4500, can i get the 3 cylinder on my truck.
Old Oct 9, 2012 | 10:51 PM
RanchhandTCR's Avatar
Yes you can, I have it on my truck. You can have the dealer flash your PCM with the program. Ive heard that some programmers have the feuture also. But my PCM is flashed to go to high idle at 10 degrees and 3 cylinder high idle at -30 degrees.
Old Oct 10, 2012 | 08:01 AM
cause i heard that you could only get it on the 2001 dodges
Old Oct 10, 2012 | 09:10 AM
RAW's Avatar
RAW
I'm pretty sure all VP44 trucks can get it.
Old Oct 10, 2012 | 11:11 AM
Farmboy 2.0's Avatar
Smarty has the capability. Once your truck is flashed with a smarty it will always be on there. Or my quad does it and I can control when the high idle shuts off via coolant temp
Old Oct 10, 2012 | 11:13 AM
RAW's Avatar
RAW
I didn't know the Quad could do that, interesting!
Old Oct 10, 2012 | 11:16 AM
Yep it has high idle that i can set to kick off from 130-190 i think it is. And I can set the delay for how long before high idle kicks in.
Old Oct 10, 2012 | 11:20 AM
H.R.D's Avatar
IMO it is a must to have a High Idle Fooler......
Mopar1973Man's Dodge Ram Cummins Turbo Diesel Forum - High Idle Fooler Set-Up for Sale!!!!
All you need to do it get it turned on by the dealership or a smarty.
Below are the high idle parameters....
File Type: pdf
Old Oct 10, 2012 | 11:32 AM
Hmmm i never seen those. I like the one on the quad its simple to use and works very well. And unlike the dealership, and the smarty it high idles until the temp its set to shut off at is. Which for me is nice because my truck idles even when its hot out before i drive it
Old Oct 10, 2012 | 11:37 AM
H.R.D's Avatar
Yeah the idle fooler can work in 100+ degree weather. So it can help cool the inside during summer and also warm the inside during winter. You can leave it on as long as you want (within reason). I don't, I just get it fooled and once it ramps up the idle I turn the fooler off and let the ecm control it.
