exhaust
Old Oct 9, 2012 | 08:48 PM
codycatract's Avatar
Default exhaust
I been researching and am buildin hi power motor a mod im really wanting to do is the tubular header, main reason is for a daily driver advantage of big drop in egts and wont have to worrie about head crack from heat warp from stocm egaust mani, anyway im looking for one of these and am curious where I can get my hands on one
Old Oct 10, 2012 | 01:18 AM
1stgenblowingsmoke's Avatar
Equal length stainless steel Cummins header
Old Oct 12, 2012 | 11:56 AM
Ive done. Alot of research about cummins headers and people say you loose power and that's understandable since a header is made for hi rpm but I want it for lower egts. Towing why im asking is can thdrop in power feel noticeable or only see it in synonymous test?
Old Oct 12, 2012 | 07:49 PM
bladeyamaha's Avatar
While we are on the topic of upgrading. LOL
M & H Inc. - Air Intakes
Old Oct 12, 2012 | 08:29 PM
BC847's Avatar
You'd do well spending that money on a nice set of towing twins IMO.
Old Oct 12, 2012 | 08:47 PM
biged681985's Avatar
Not worth the money IMO. Most I'd go with is just a three piece exhaust manifold.
The guy who is tired of driving a suburban
Old Oct 12, 2012 | 08:54 PM
Ive done. Alot of research about cummins headers and people say you loose power and that's understandable since a header is made for hi rpm but I want it for lower egts Towing, what im asking is the drop in power feel noticeable or can you only tell it in dyno test?
Old Oct 12, 2012 | 09:39 PM
BC847's Avatar
How do you figure that header is gonna give you a drop in EGTs? The thin-wall tubing?
Keep in mind the turbo(s) is driven by the otherwise wasted energy of heat in the exhaust gasses. Unless I'm mistaken, our heavy-walled exhaust manifolds benefit the turbo as it doesn't shed heat as fast. With that, there's more energy to drive the turbo.
Further, yes, the tubular header will provide certain advantages in certain circumstances, but the tubular header that's properly tuned is gonna be peaky in its window of response/benefit. The more traditional log header is gonna tend to broaden the range of benefit/response.
If you're serious about dropping the EGTs, look harder at a set of conservative/responsive twins. An aftermarket cam shaft will help move a lot of air through the engine.
- The tubular header for a diesel isn't anything new. If they worked that well for a daily-driver / work truck, everybody would be running them.
Just my $0.02.
Old Oct 13, 2012 | 11:48 AM
36Valved I6s's Avatar
Best bet for your money I would recommend a Steed Speed Manifold CNC an very nice!
Old Oct 15, 2012 | 07:41 AM
Like I've been Told a header as upgrading exhaust housing. More flow is less heat. Log manifold is restrictive compared to a header witch causes heat. It has been tested and proven on paper its drop on average 100 degree egt. I know Somone that has a cheapyy one and he had egts drop but spool up was slower. But like anyone know you can't have the best of both worlds a quicker spool system will run hotter I was just cerious if anyone has actually had one I wanted to hear what they would have to say about it thank though I would do mani but. Header runs cooler and its Somthing different ill let you guys know what I get out of the hole deal thanks
More volume results in more lag time but also for the more volume reduces heats, that is just what I learned over the years and seeing dyne runs to back it up but im no expert I could be wrong in some circumstances
Last edited by codycatract; Oct 15, 2012 at 07:44 AM. Reason: Automerged Doublepost
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
