tdc help
Old Oct 9, 2012 | 11:26 AM
carpssublime's Avatar
Default tdc help
Does anyone have a good link to find tdc? I'm hoping for pictures with instructions if at all possible. thanks
Old Oct 9, 2012 | 06:23 PM
cumminstothefloor's Avatar
The timing pin is located at the back of the gear housing and below the injection pump. Fitting the timing pin into the hole in the crankshaft is tricky, spin the harmonic balancer and watch the valve the train until the #1 exhaust valve closes, then turn the crankshaft about 90 degrees. If the timing pin will not engage, spray it with some penetrating oil to loosen it.
When the pin engages the hole in the camshaft gear, cylinder No. 1 is at TDC on the compression stroke. Be sure to disengage the timing pin after locating top dead center.
B Series Valve Adjustment
I know it's vlave lash adjustment, but it tells how to find tdc in step 4
Last edited by cumminstothefloor; Oct 9, 2012 at 06:24 PM. Reason: Automerged Doublepost
Old Oct 10, 2012 | 09:29 AM
hey thanks, appreciate it. gonna get to it this weekend hopefully.
51Hudson
55
Jul 8, 2018 08:17 AM
