3200 gov spring installed truck wont run!
Old Oct 8, 2012 | 10:56 PM
78fordf150ranger's Avatar
Default 3200 gov spring installed truck wont run!
Okay installed my new gov spring today and now the truck won't run I tryed priming the pump before starting nothing.tryed holding the peddle to the floor nothing I'm sure I have it indexed right any help or tips ? I left my full power screw the same could this be the problem?
Old Oct 9, 2012 | 03:28 AM
bladeyamaha's Avatar
No, prolly not, crack a line at one or two of the injectors and turn it over, Once you get fuel there to at least one, two would be better, then retighten the injector lines, it may fire right up then, if that's not the problem, you may have installed improperly, I have not installed one yet but you can try my suggestions easily enough with no real losses. Hope it works. Have a better day man, I hope!
Old Oct 9, 2012 | 08:22 AM
92betsy's Avatar
Did you take the power screw out before doin the spring, and put it back in after replacing the head back on the pump?
Old Oct 9, 2012 | 08:38 AM
wondering................
Old Oct 9, 2012 | 09:41 AM
willyslick's Avatar
i did mine same problem.i watched video on utube and it said when you take fuel pin out look in bore and actuate throttle lever if pin does not move there is problem.this is my problem my pin not moveing i am working on this right now,.can anyone help.why pin not moveing?
utube video (bd gov spring)
Old Oct 9, 2012 | 08:42 PM
I pull the full throttle screw before reassembly. I got it running if you want to call it that. A ton of white smoke hardly running stumpling and had to kinda feather the throttle to keep it running
Old Oct 9, 2012 | 10:08 PM
92betsy's Avatar
Mine did that with the index off.
Old Oct 10, 2012 | 01:15 AM
1stgenblowingsmoke's Avatar
Yeah your indexing is off. The throttle arm has to be rotated clockwise more.
Old Oct 10, 2012 | 09:32 PM
What about leaking from the throttle shaft? Normal?
Old Oct 11, 2012 | 12:00 AM
lodal cummins's Avatar
No not normal, there is a o ring on that shaft either gone or bad. As for the pin not comming out take the pump top back off and make sure the lever is toward the firewall.
