P132B?
I'm haveing this code keep poping up own my programmer. I have replaced the right side y pipe checked for leaks. cleaned the egr valve to make sure it wasn't sticking and the mfs sensor and air filter. I'm running a cold air intake a edge evolution programmer with the stock exhaust except with the cat deleted any ideas would be greatly appreciated. I also had the turbo vanes cleaned to make sure they wasn't sticking
It's usually a turbo issue.
Check this out: Code P132B and turbo noise - PowerStrokeNation : Ford Powerstroke Diesel Forum
Absolutely. No fuel to burn means no heat, which drives the turbo... however I doubt that's your issue, if you had low fuel pressure you'd know it. It would also be destroying your injectors.
I have seen cases before where just simply having an aftermarket intake will cause the code. Do you have the stock box kicking around just to try?
