7.3 upgrades??
Old Oct 8, 2012 | 03:20 PM
94 turbodiesel's Avatar
Default 7.3 upgrades??
so, as of now i'm only 14, about to turn 15. My dad told me he is giving me his 1994 f250 turbodiesel idi. I was wondering what upgrades i could do, or any tweaks i could do to get more power. As of now the only things done to it is we straight piped it, and turned the fuel up a little on it, but other than that it's stock. Any help would be appreciated!
Old Oct 11, 2012 | 12:54 PM
JRauton18's Avatar
Default well.....
well you arent going to need more power unless your one of those people who have a diesel for the look and think their cool or your hauling heavy loads, whats your reason for wanting more power
Old Oct 11, 2012 | 01:54 PM
Well, its not that I'm power hungry, I want to get better mileage. I'm not expecting anything over 19, but I'm only getting about 14 now, and I'll be driving this truck for quite a while.
Old Oct 11, 2012 | 03:51 PM
JRauton18's Avatar
first thing to tackle would be the breathing of the engine which would be a good aftermarket air filter to improve air flow, gearing in the differential could be a low ratio for towing, you can get different gearing but thats expensive, and performance chips, yours will have a computer and you can get performance chips from pretty much any company but i would suggest TS performance chips.
Old Dec 3, 2012 | 09:20 PM
BVFD54's Avatar
First JRauton18 if he has a 1994 IDI turbo engine this is a NON computerized engine... no performance chips... different if he has the 1994.5 POWERSTROKE that is not an IDI and is computerized... but you are correct on air intake aftermarket filter to help. Another thing would be to get rid of the stock downpipe if that hasnt been done already to free up the exhaust side.
Old Dec 18, 2012 | 09:12 PM
7.3idiboy's Avatar
94 idi engines are mechanical not electrical and can not use chips. and i se why you want more power even if you dont need it its awesome!! turning up the wastgate will help as will adding a water/meth unit (its worth it) also a cold air intake and bigger downpipe will help. you can turn up the ip if you want more power but it wont help your fuel econemy
Old Jun 22, 2013 | 10:39 PM
daves93f250's Avatar
You can run more boost, but you will need studs.
Old Jun 23, 2013 | 04:17 PM
4x4manonbroke's Avatar
If u run boost .... u will neeed a lot more than just studs ..... about 10psi is truly a maximum ... yes u could run more but relaibility becomes an issue .... unless u wanna spend some real cash ... keep it simple big air cleaner , big exhaust , and keep ur coolant sca's in check .... toss in some atf in the tank .... full quart for the first two tanks then half quart after that .... keeps injectors clean .... Pm me if u want specific info
Old Aug 2, 2013 | 03:43 PM
TexAg's Avatar
One huge thing with mileage is just get your fuel pump set nice. Too high and you're wasting fuel burning it as smoke
Old Aug 15, 2013 | 08:29 PM
yup .... smoke = fuel out the pipe
Browe347
Dec 11, 2016 02:59 PM
Devon7.3
Sep 27, 2015 10:35 PM
tumble72
8
Nov 27, 2014 10:31 PM
Altonlee
9
Oct 8, 2014 02:31 PM
Browe347
Sep 30, 2014 11:35 PM
